Far end of shadow noise
Posted: Wed May 29, 2019 8:57 am
This might be normal behavior but if there is an object currently in a far end of shadow of an object, that area won't get denoised. Not sure if noise samples are too far inbetween or there is a correlation but denoiser won't do anything with those areas unless they are very low in noise.
In my test example I needed over 2500 samples for the area to get properly denoised and it's still kinda not perfect.
10samples
10samples denoised
50samples
50samples denoised
500samples
500samples denoised
scene:
noise_denoise_shadow.blend
(980.46 KiB) Downloaded 139 times
Is this normal? Or maybe oidn related issue?
Re: Far end of shadow noise
Posted: Wed May 29, 2019 10:07 am
That is quite strange, are you using "tiled denoising" ? It may be a bug introduced with that patch, I will check.
Posted: Wed May 29, 2019 10:11 am
nope, this is normal denoising. I haven't even seen tiled denoising in blender actually
Posted: Thu May 30, 2019 7:37 am
I can reproduce the problem but I can not see any error on our side.
I will upgrade the binaries to the latest Oidn version than, if the problem is still there, I will report behavior to Intel.
Posted: Thu May 30, 2019 10:14 am
Dade wrote: Thu May 30, 2019 7:37 am I can reproduce the problem but I can not see any error on our side.
Good, by the way, this can also happen in a more complex environment.. It always kinda seems related to very soft shadow. I assumed that maybe there is some pattern that oidn recognizes in that part.
Posted: Thu May 30, 2019 1:14 pm
by wasd
lacilaci wrote: Wed May 29, 2019 8:57 am denoiser won't do anything with those areas unless they are very low in noise.
I've got similar behaviour in this scene download/file.php?id=4471.
It's Glossy Translucent mixed with Null, with homogeneous multiscattering volume.
Posted: Thu May 30, 2019 2:20 pm
by CodeHD
I did expereince some issues as well (though not this one) when there were completely black background areas in my image.
Have you tried computing albedo and average shading normal AOVs as well? I had the feeling that helped the algorithm.
Posted: Thu May 30, 2019 2:28 pm
CodeHD wrote: Thu May 30, 2019 2:20 pm Have you tried computing albedo and average shading normal AOVs as well? I had the feeling that helped the algorithm.
They are always enabled in BlendLuxCore if the denoiser is used.
Posted: Thu May 30, 2019 2:40 pm
by CodeHD
B.Y.O.B. wrote: Thu May 30, 2019 2:28 pm They are always enabled in BlendLuxCore if the denoiser is used.
Hmm ok, it seems I was just wrong with that feeling.
I just tried that scene I had in mind again (indeed no difference when including albedo + nromal aov), and it seems to depend also on where I focus in that case, with the result failing completely when my object is defocused (which unfortunately is the scientifically correct case for that instrument :D ):
focused case (works):
defocused case (doesn't work):
Posted: Thu May 30, 2019 4:17 pm
I think it's OIDN 'failing' to achieve human anticipations... did observed similar issues on occasions & also with NVidia's denoiser... more so, all over noticing critiques about this tech. Human adapted, tolerance raised...
And a reminder, during NVidias first AI filtering/denoising demo it was noted that this tools are meant for better, faster, more efficient previewing!!! not final HQ renders. ;)
