PGI Problem
Re: PGI Problem
Post by Sharlybg » Mon Jun 03, 2019 12:30 pm
B.Y.O.B. wrote:
Mon Jun 03, 2019 11:44 am
Unfortunately I can't reproduce it here with your scene, even on win10.
Does it only happen if you save/load the cache?
But try to first compute and save the pgi file in your folder. Then diasable compute save so the engine will use the old precomputed .pgi cahe. then before you press F12 delete or move the .pgi to another folder so luxcore can't find it and don't know that a new cache need to be computed.
Re: PGI Problem
Post by B.Y.O.B. » Mon Jun 03, 2019 12:33 pm
When I do that it just says "no cache file available" and a fresh cache is computed before the render starts.
Re: PGI Problem
Post by Sharlybg » Mon Jun 03, 2019 6:42 pm
Another Strange thing with my blendluxcore is that twos hawai Gpu are listed in the Device panel.It is weird because i've installed only one. and there was never two hawai GPU installed in this config.
I'd made some clean driver unisntall an reinstall but Nothing work. Team RED wish me to have 2 GPUs :lol:
Re: PGI Problem
Post by B.Y.O.B. » Mon Jun 03, 2019 6:51 pm
Weird :)
You could download LuxMark and check if that also lists the GPU two times.
Re: PGI Problem
Post by kintuX » Fri Jun 07, 2019 4:11 pm
Dade wrote:
Thu May 30, 2019 6:01 pm
kintuX wrote:
Thu May 30, 2019 4:22 pm
Same here, last few days more crashing occurs... especially when trying to preview. No culprit found :?
PGI is disabled on view port rendering (if the at is the meaning of "preview") so I doubt it can crash your renders.
I just had doubts. Anyways, all stable now. 8-)
