Curtain shader
Curtain shader
How should I approach making curtain shader in luxcore, seems both matte translucent and glossy translucent don't let sunlight through at all.. why?
Re: Curtain shader
As far as I know the translucent materials scatter the transmitted light in all directions.
If you want to have some light passing through in it's original direction, I would suggest to lower the opacity of the material a bit.
Could you post some reference images what kind of curtain you look for? Thicker cloth or lighter?
Here's a basic attempt by me, maybe it helps:
- Attachments
- curtain.blend
- (100.48 KiB) Downloaded 285 times
Re: Curtain shader
Thanks, well I guess it's either lowering or mapping opacity...
Which makes sense I guess but I thought that making the material transmit all light will also lower scattering/roughness.
I think I'm just too used to hiding curtain shadows completely
Re: Curtain shader
Curtain is a complex matter. First, for some reason SSS in luxcore is allowing less light through than expected. At least, less than I excpect, so it doesn't really looks realistic, unless you add some opacity.
Second is, if you look closely to fabric, it has a lot of holes between threads. That's the main reason the light comes through. The threads itself allow very little light through.
I use fabric black and white texture for opacity.
