Re: Interior & exterior gghouse
Posted: Fri May 17, 2019 1:07 pm
http://forums.luxcorerender.org/
CoolColJ shared nice water material, it's still up in Indigo material database.Peperepe77 wrote: ↑Tue May 14, 2019 2:40 pm Hi guys, this is an update for exterior scene. I need help to create a good water material for the pool; now is a simple plane with glass material IOR 1,333.I should to add interior or exterior volume? There is a lux tutorial? Here references https://www.archdaily.com/907558/gg-house-sommet
Just use gain colorlacilaci wrote: ↑Fri Jun 14, 2019 11:30 am I wonder where is the weird green/yellowish colorcast from sunlight coming.
I find luxcore sun incredible difficult to control especially without proper white balance controls in camera. The moment it goes closer to sunset/sunrise, the whole sun&sky system becomes pain. We need the ability to directly control sun color and in camera WB controls too.
even desaturated sun color and even disconnected from sky model it will still turn weird yelowish cast when nearing sunset/rise angles. The only way around it is using direct light.Sharlybg wrote: ↑Fri Jun 14, 2019 11:33 amJust use gain colorlacilaci wrote: ↑Fri Jun 14, 2019 11:30 am I wonder where is the weird green/yellowish colorcast from sunlight coming.
I've wrote a very very naive white balance plugin a while ago. I will clean it up, rebase and make a pull request so you can test it to see if that helps.lacilaci wrote: ↑Fri Jun 14, 2019 11:30 am I wonder where is the weird green/yellowish colorcast from sunlight coming.
I end up with this with the same HDRI : (Only gain color correction)Peperepe77 wrote: ↑Sat Jun 15, 2019 2:15 pm My scene is lit with Hdri https://hdrihaven.com/hdri/?c=sunrise-s ... it_sunrise
