Page 3 of 5
Re: LuxCoreRender v2.1alpha4 released
Posted: Fri Sep 28, 2018 4:19 pm
Dez! wrote: ↑Fri Sep 28, 2018 2:03 pm
Thank you. disabling bloom, I got the Alpha 4 job.
but I need bloom.
Try to disable film OpenCL image pipeline and just switch film CPU image pipeline (I think B.Y.O.B. has added the support for this option to BlendLuxCore). It should work around the problem.
problem with the denoise remained. he kills the gloss.
Tomorrow, I will check this problem.
Posted: Fri Sep 28, 2018 5:26 pm
by Dez!
Thanks. very await the
Posted: Fri Sep 28, 2018 5:42 pm
Dade wrote: ↑Fri Sep 28, 2018 4:19 pm
Yes, the option is in the imagepipeline settings (camera properties), next to the transparent film option.
Posted: Fri Sep 28, 2018 6:22 pm
by Dez!
Yes Alpha 4 to work. and the effect glow is working.
Posted: Sat Sep 29, 2018 10:26 am
I fixed the OpenCL Bloom plugin problem but I'm unable to reproduce the denoiser related problem. It is working fine here:
Do you get different results ? Is it a Windows only problem ?
Posted: Sat Sep 29, 2018 11:00 am
Try this scene:
viewtopic.php?f=4&t=385#p4495
On my Linux, it shows the problem.
Posted: Sat Sep 29, 2018 11:47 am
by Dez!
I understand the answer correctly?
you can animation from the blender to export to the Standalone version of Luxrender.
and there are no problems with the denoiser in it.
Posted: Sat Sep 29, 2018 5:23 pm
by Dez!
I found out why buggy denoise.
Denoise kills the gloss if the scene has Hemi Light HDR
If you only cover the scene with the World HDR, then the denoise works correctly.
![Image](https://i.imgur.com/NunTyIH.jpg)
Posted: Sat Sep 29, 2018 6:07 pm
by Dez!
after joyful jumped 5 minutes I continued to explore the problem
it turns out, it's not in Hemi
it turns out, the fact is that there is no World HDR in the scene. And there are only Hemi.
If the scene is lit World HDR, everything is fine
Posted: Sun Sep 30, 2018 1:07 pm
by marcatore
I have a problem with glossy material.
It seems that the reflections doesn't work. Anyone else?
