Page 3 of 5
Re: Moving from classic LuxRender
Posted: Thu Oct 04, 2018 6:05 pm
by lighting_freak
OK, I did everything from zero.
There is no error anymore, but the render didn`t start at all.
Is it a problem if you run the console and the node is running on same machine?
![2018-10-04_200128.png (89.17 KiB) Viewed 4666 times Console](./download/file.php?id=2186&t=1&sid=9e40ed258be3fd4b47af8dd2e6dd9525)
- Console
![2018-10-04_200157.png (85.34 KiB) Viewed 4666 times Node](./download/file.php?id=2187&t=1&sid=9e40ed258be3fd4b47af8dd2e6dd9525)
- Node
It seems that the connections works well. Also the job file seems to be fine. Only the network rendering doesn`t start.
P.S. Network rendering is highly un-test.
OK - let`s test it!
BR
Posted: Thu Oct 04, 2018 6:22 pm
lighting_freak wrote: ↑Thu Oct 04, 2018 6:05 pm
No, it's not a problem.
Posted: Thu Oct 04, 2018 6:34 pm
by lighting_freak
It`s still not working.
Well, so we need a new idea!
Posted: Thu Oct 04, 2018 7:41 pm
by acasta69
No errors or different messages in the netnode console?
Posted: Thu Oct 04, 2018 8:32 pm
acasta69 wrote: ↑Thu Oct 04, 2018 7:41 pm
It is a "known" bug, it happens only on Windows (Linux works fine) and it is something I still need to investigate, there is some kind of deadlock, like if some part of the network packet exchange is lost.
Posted: Fri Oct 05, 2018 7:42 am
by acasta69
Ok, now I have seen the old related thread and issue.
However I can't reproduce it here.
Posted: Fri Oct 05, 2018 8:51 am
by lighting_freak
new day new chance. Today I've started the Console and the Node.
I've been loading the same exported rendering file I've loaded yesterday - and see, it's working.
I don't have any idea what's different, but anyway...
I tried to connect a second machine (node) and it was working perfectly.
Then after some time I tried to stop the job to see the result.
This messages appear in Console's console (sorry for using a screenshot but there is chance to select the text):
![2018-10-05_104645.png (97.01 KiB) Viewed 4633 times Error message](./download/file.php?id=2192&t=1&sid=9e40ed258be3fd4b47af8dd2e6dd9525)
- Error message
By the way - whats the idea of continue work after network rendering has been finished?
I saw (and hope) that a *.flm file should be written. Knowing this extension from old lux makes me hoping that tonemapping and lightgroup scaling etc. can be done in a postprocessing step? At the moment I don't see any option to open this file type, neither in luxcoreui nor somehow in blender.
But OK, let's dig into that later step by step.
Thanks so far.
BR
Posted: Fri Oct 05, 2018 9:29 am
lighting_freak wrote: ↑Fri Oct 05, 2018 8:51 am
Are you sure you are not mixing different versions like alpha3 and alpha4 ? The error is quite strange.
Yes, there is a directory with .flm and many other files, if you restart the rendering it will continue because the directory already exist.
It is possible but very complicate border line impossible for an end-user. We are currently lacking an application with a GUI to perform the aforementioned operations.
Posted: Fri Oct 05, 2018 10:32 am
by lighting_freak
I checked the versions one more time and they are equal.
Both setup use acasta69´s pyluxcoretool.exe
The only difference is that on the "Console-machine" this is executed from a Standalone download od luxcore (V2.1 lpha4) and on "Node-only machine" it's executed from a blendluxcore setup. In both cases has the origiinal *.exe file been replaced by the new one.
Well, not so many files after stopping the job, propably caused by the error.
![2018-10-05_122907.png (18.88 KiB) Viewed 4620 times rendering folder](./download/file.php?id=2193&t=1&sid=9e40ed258be3fd4b47af8dd2e6dd9525)
- rendering folder
What about using the "old" interface?
BR
Posted: Fri Oct 05, 2018 11:43 am
lighting_freak wrote: ↑Fri Oct 05, 2018 10:32 am
It is using the old LuxRender API, not the new LuxCore API.
