Re: Mac OS
Posted: Fri Jan 25, 2019 9:54 am
Done, thanks for the reminder.
http://forums.luxcorerender.org/
PLEASE TELL ME HOW YOU FIXED IT!jensverwiebe wrote: ↑Sat Jan 20, 2018 4:26 pmThats what i immediately thought when seeing the new embree libs come with @rpath id: rpath is a wonky thing on macOS, i made them loader_path now, works more reliable.AndreD wrote: ↑Fri Jan 19, 2018 6:44 pm Hi,
I am just trying the first mac version,
I get this error:
Traceback (most recent call last): File "/private/var/folders/qr/g00zj9_91m3_xs4l5c5lvykc0000gn/T/AppTranslocation/93244D79-C0F7-42A3-BE5D-378F82ED9B17/d/blender.app/Contents/Resources/2.79/scripts/modules/addon_utils.py", line 331, in enable mod = __import__(module_name) File "/Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/__init__.py", line 2, in <module> from .bin import pyluxcore ImportError: dlopen(/Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so, 2): Library not loaded: @rpath/libembree.2.dylib Referenced from: /Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so Reason: image not found
Jens
That's your 2010 iMac?FarbigeWelt wrote: ↑Sat Feb 02, 2019 2:58 pm Today, I run a few tests with openCl. Sample count and speed of GPU are an not as i expected them.
I had the same thoughts, and closed all other apps but without change. I will check with luxmark if it shows the same behaviour.epilectrolytics wrote: ↑Sat Feb 02, 2019 5:56 pm
EDIT: Just spying at your dock it seems a lot of apps are open.
Now when testing render performance I would close all other apps, also networks.
Again Activity Monitor reveals if any background process is eating away CPU capacity.
Yes, it is my 2010 iMac.epilectrolytics wrote: ↑Sat Feb 02, 2019 5:56 pm That's your 2010 iMac?
I guess if the GPU is weak there is no point in using it:
Well I'm glad was wrong
No, I have not noticed it at all.
[LuxCore][604.525] Starting 1 OpenCL render threads
[LuxCore][604.654] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Kernels cached
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Compiling Film_Clear Kernel
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Compiling InitSeed Kernel
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Compiling Init Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_NEXT_VERTEX Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_NOTHING Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_OBJECT Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_DL Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[b][LuxCore][604.669] [PathOCLBaseRenderThread::0] Kernels compilation time: 19ms[/b]
[LuxCore][604.686] Starting 0 native render threads
[LuxCore][604.707] Film OpenCL image pipeline
[LuxCore][604.707] Film OpenCL Device used: ATI Radeon HD 5750 Intersect
[LuxCore][604.707] Device OpenCL version: OpenCL 1.2
[LuxRays][605.276] [Device ATI Radeon HD 5750 Intersect] IMAGEPIPELINE buffer size: 22500Kbytes
[LuxRays][605.276] [Device ATI Radeon HD 5750 Intersect] Merge buffer size: 30000Kbytes
[LuxCore][605.276] [MergeSampleBuffersOCL] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][605.276] [MergeSampleBuffersOCL] Compiling kernels
[LuxCore][605.277] [MergeSampleBuffersOCL] Kernels cached
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeBufferInitialize Kernel
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_PIXEL_NORMALIZED Kernel
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_SCREEN_NORMALIZED Kernel
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeBufferFinalize Kernel
[b][LuxCore][605.277] [MergeSampleBuffersOCL] Kernels compilation time: 1ms[/b]
[LuxRays][605.816] [Device ATI Radeon HD 5750 Intersect] Accumulation buffer size: 175Kbytes
[LuxCore][605.816] [Reinhard02ToneMap] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][605.817] [Reinhard02ToneMap] Compiling kernels
[LuxCore][605.817] [Reinhard02ToneMap] Kernels cached
[LuxCore][605.817] [Reinhard02ToneMap] Compiling OpRGBValuesReduce Kernel
[LuxCore][605.817] [Reinhard02ToneMap] Compiling OpRGBValueAccumulate Kernel
[LuxCore][605.817] [Reinhard02ToneMap] Compiling Reinhard02ToneMap_Apply Kernel
[b][LuxCore][605.817] [Reinhard02ToneMap] Kernels compilation time: 0ms[/b]
