weird volumetric lighting glitch
Re: weird volumetric lighting glitch
spot works sun but sun is broken still
A general comment about the scene: your volume setup is incorrect, this makes camera volume auto-detection fail.
You can either:
- set the correct exterior volume on all materials
or
- disable volume auto-detection in the camera settings and manually set the exterior camera volume
(the latter is simpler)
About the weird stripe: I can reproduce it even with just the volume cube and the sun. Maybe it's a bug, or maybe some other problem in the scene that I couldn't find.
You can either:
or
- Attachments
- Capture.PNG (9.25 KiB) Viewed 4385 times
- WTF3.blend
- (2.39 MiB) Downloaded 161 times
yeah its a bug no amount of settings fixes it and its only with sun lamp problem it seems
Camera volume always fail. At least in luxcore 2.1 and earlier.
Do you mean the auto-detection? A bug in that code was fixed a while ago, probably after v2.1.
I mean any camera volume setting beside "---" will not work.
You've fixed something before 2.1 and after that camera volume still should be set to "---" for volumes to work at all. It was a while since I've checked though. I'll check latest release a little later.
UPD: 2.2 beta1 still doesn't work for me
https://dropmefiles.com/mOAN4
can we get a hotfix for this bug
- FarbigeWelt
- Contact:
Only BiDir leads to a denoisable results. openCL path renders patterns which cannot be denoised currently. Please have a look at the next pictures.
MacBook Air with M1
MacBook Air with M1
