Page 2 of 2
Re: LuxCoreRender v2.2beta1 released
Posted: Fri May 03, 2019 2:09 pm
by epilectrolytics
provisory wrote: ↑Thu May 02, 2019 9:40 pm
And here is the Blender file: leaf0006.blend
Thank you!
Posted: Tue May 07, 2019 5:30 pm
by Taka
Custom viewport color doesn't work if it's assigned in Cycles first. It works if you assign the color in lux first though. In my case, I'm converting objects from Cycles to LuxCore but most objects have viewport color assigned in Cycles already. Now I can't do anything in lux, it's all gray. Is this something easily fixed or any workaround?
Posted: Tue May 07, 2019 6:09 pm
Taka wrote: ↑Tue May 07, 2019 5:30 pm
I looked into it and it seems to be triggered by the "use_nodes" property of the material. If use_nodes is True, the OpenGL viewport seems to use a different code path to display the material than when use_nodes is False.
I do not see a fix or workaround for this problem yet.
Posted: Tue May 07, 2019 6:28 pm
by Taka
Thanks for looking into it. Hopely you can figure it out!
Posted: Tue May 07, 2019 6:47 pm
Apparently, if I set "bl_use_shading_nodes" to True, we get the same OpenGL shading as when using Cycles.
But I have to investigate first what other consequences this has, it might be that I left it disabled for a reason.
https://github.com/LuxCoreRender/BlendL ... t__.py#L29
One problem I already found is that in the "material" shading mode, it shows the Cycles material, which might confuse users.
Posted: Tue May 07, 2019 10:04 pm
by sanjinms
From my experience, try to remove all UV maps.
Posted: Tue May 07, 2019 10:08 pm
by Odilkhan Yakubov
Thanks for the new release. And what about the baking textures feature?
Posted: Fri May 10, 2019 6:51 am
by Racleborg
Hi
I'm struggling to get this latest version to install?
I've installed the required Visual C++ Redistributable Packages for VS 2017
Screenshot attached
Thank you
Posted: Fri May 10, 2019 9:17 am
Unfortunately this exception does not tell us much.
Does it work with the non-opencl release? If that's the case, try updating your graphics driver, there might be an issue with the OpenCL installation.
Posted: Fri May 10, 2019 9:46 am
by Racleborg
It was the drivers. (now updated).
Thank you
