problem with orthographic camera
mick
Post by mick » Sat Feb 09, 2019 3:37 pm
I've a simple scene: a box with open top, roughly a quarter of the top covered by a glass plate, the sun in zenith, no sky2 or other lights. Just the bottom of the box and a black plane below that bottom is camera visible.
Rendered with default camera origin just below the top looking to the center of the bottom looks like I would expect: a quarter in partial shadow
When I change to orthographic camera at same position the result becomes odd: the shadow is lighter than the fully irradiated area
The only difference is:
        # "scene.camera.type", "orthographic",
        # "scene.camera.screenwindow", window,
When I move the orthographic camera close to the bottom the result is even stranger: light shadow with circular pattern (from sun, shadow of cam???)
Please help me. I'm completely lost.
Thx
Re: problem with orthographic camera
Post by Dade » Sat Feb 09, 2019 4:02 pm
I assume you are using a path tracer rendering engine. It is nearly impossible for a path tracer to find the tiny sun circle in the sky. As a proof, just try to render a room with glass windows. It is the reason why "archglass" material exists and why it should be used in the room case. The other option is to use bidirectional path tracing: it is able to render this type of light setup.
There may be other problems (like numerical precision problems) in your scene but I can not add more without having a scene to test.
mick
Post by mick » Sat Feb 09, 2019 5:52 pm
No, I'm using BIDIRCPU.
I need to simulate optical lenses. I've no idea what archglass does. But I assume it does some tweaks, so it would prevent physical realism for sculptured lenses, right?
I don't think that there is a numeric issue. There are no extreme dimensions or ratios.
What can I send you to check? I've no blender file. Everything is generated with pyluxcore. I created the scn, cnf, and ply files. Actually the are already attached to the origninal thread: viewtopic.php?f=4&t=884
Post by epilectrolytics » Sat Feb 09, 2019 6:06 pm
Looks like the box has no thickness, i.e. inner and outer walls.
That could cause light leaks at the corners.
Also smoothing can cause weird shadows.
But I don't know Python and have no idea how to inspect the scene without Blender.
Also no experience with orthographic camera here.
mick
Post by mick » Sat Feb 09, 2019 9:25 pm
I created the scene in blender, more or less. At least it shows the same strange behavior for orthographic camera.
File attached.
To compare just move to camera to e.g. z=-1 or switch to Perspective.
BTW: How to make objects camera invisible in blender?
plate.blend
(613.84 KiB) Downloaded 40 times
Post by Dade » Sat Feb 09, 2019 9:39 pm
This: viewtopic.php?f=4&t=881#p9419
mick
Post by mick » Sat Feb 09, 2019 9:57 pm
Thanks, I found the flag.
I found out that the orthographic rendering looks fine when I change the opacity of the glass to 0. Opacity seems to have no effect on perspective camera.
What is a glass opacity when a volume is defined???
Post by Dade » Sat Feb 09, 2019 10:19 pm
Opacity is supposed to be used for some very specific rendering task like leafs and masks, it makes the rays just go trough the object like if it doesn't exist. So setting the opacity to 0 is like removing the object from the scene.
Note: Blender plugin uses the "opacity" term while LuxCore SDL "transparency" and 0.0 is translated in 1.0 and vice versa.
Mixing opacity and an already transparent material like glass doesn't make very much sense and can do a huge mess if volumes are involved.
Post by B.Y.O.B. » Sat Feb 09, 2019 10:34 pm
Actually the 0-1 scale is not reversed.
LuxCore just uses the wrong term in my opinion, because in LuxCore, at "transparency = 1" (true) the object is opaque, while at "transparency = 0" (false) it is transparent. So I use "opacity = 1" (true) for opaque and "opacity = 0" (false) for transparent.
mick
Post by mick » Sat Feb 09, 2019 10:53 pm
OK, but this bring me back to the point that orthographic camera does not work.
