LuxCoreRender v2.1 released
Re: LuxCoreRender v2.1 released
Can you post a testscene that shows the problem?
Its a problem with missing materials.
If I import an object and any material zone's have not been given a Luxcore material, then I get the error/problem.
In previous builds, an imported object with missing Luxcore mats would render, and I would be given warnings about missing mats.
Do I need to post a test scene? You could import an object(.obj) and check.
Thanks for the report, I fixed the bug.
I think I'll wait a few days if any more bugs are found and repackage the BlendLuxCore release then (I don't think we need a v2.1.1 for only one bug, I can just move the v2.1 tag).
Thanks for checking/fixing the bug.
Another issue, but it is unpredictable. When a render is in progress(just after starting), I can get an error showing(which stops the render) of:-
Report: Error
Writing to ID classes in this context is not allowed: Scene, Scene Datablock, error setting LuxcoreConfigPath.suggested_clamping value
The error can show, but when restarting the render(with no changes) it will render OK without the error.
Report: Error
I've seen this happen a couple of times in the past. But when restarting the render the message has gone. I had presumed that, in my case, the error was a user error as opposed a software one.Writing to ID classes in this context is not allowed: Scene, Scene Datablock, error setting LuxcoreConfigPath.suggested_clamping value
I think this is a bug in BlendLuxCore, appparently a render engine is not supposed to modify the scene data during the render.Stem wrote: ↑Sun Jan 13, 2019 12:11 pm Another issue, but it is unpredictable. When a render is in progress(just after starting), I can get an error showing(which stops the render) of:-
Report: Error
But it seems to fail only very rarely. However, we will have to fix this in the future. For now, I have only added a safety net so the error doesn't end the render anymore.
Thank you for the report.
I have moved the v2.1 tag to include the latest fixes and re-uploaded the BlendLuxCore v2.1 binaries.
good to see luxcore news on evermotion: https://evermotion.org/articles/show/11 ... 2-1-is-out
Nicelacilaci wrote: ↑Mon Jan 21, 2019 4:10 pm good to see luxcore news on evermotion: https://evermotion.org/articles/show/11 ... 2-1-is-out
