Luxcorerender with FreeCAD 0.17
Hello,
I'm trying to render a file exported from FreeCAD 0.17 in luxcorerender-v.2.0-win64-sdk but get this error:
Luxcore RUNTIME ERROR: Invalid IES file in property scene.materials.LUXCORE_MATERIAL_skyplane_0.emission
Does anyone now how to fix this?
The cad object is exported to a .lxs file as illustrated in the figure below, and then opened in luxcorerender.
I added the FreeCAD 0.17 file and the exported .ilx file in the attached zip.
A video recording of the problem can bee seen here https://youtu.be/50Tt_UtTwAo
- example.zip
- (322.37 KiB) Downloaded 230 times
Re: Luxcorerender with FreeCAD 0.17
I think this bug is already fixed in v2.1, you could try with a recent build.
https://github.com/LuxCoreRender/LuxCore/pull/123
To stay in my comfort zone, Is there a Windows binary available of 2.1?
Using luxcorerender-v2.1beta4-win64 the FreeCAD 0.17 scene renders, but with a layer of white stripes on top, as shown in the image below. However, the cornell scene looks fine.
Is there any documentation/tutorials about the settings used in .lxs, .scn, and .cfg files? For example, how to set a stop criteria for a render, adjust the resolution, and how to save image files. I can not find this information on the LuxCoreRender User's Manual page.
The .lxs file used for this render is attached.
- box05.zip
- .lxs file used for the render
- (1.87 KiB) Downloaded 200 times
I have never seen this before - maybe a bug?photonbuzz2 wrote: ↑Sat Dec 29, 2018 7:10 am Using luxcorerender-v2.1beta4-win64 the FreeCAD 0.17 scene renders, but with a layer of white stripes on top, as shown in the image below.
If you post your scene we can test if we can reproduce it.
This information is in the SDL (scene description language) reference manual:photonbuzz2 wrote: ↑Sat Dec 29, 2018 7:10 am Is there any documentation/tutorials about the settings used in .lxs, .scn, and .cfg files? For example, how to set a stop criteria for a render, adjust the resolution, and how to save image files. I can not find this information on the LuxCoreRender User's Manual page.
https://wiki.luxcorerender.org/LuxCore_ ... anual_v2.1
I got this stripe pattern when using BidirVCM with sobol sampler in LuxCoreUI.
Very slowly the stripes get longer until they cover the whole image.
They show the real render, the image beneath the stripes looks like a prepass or AOV or something.
Yes, the scene posted by photonbuzz2 uses BIDIRCPUVM because the LuxCore LXS parse maps old Lux "bidirectional" surface integrator in LuxCore BIDIRCPUVM render engine ... I have really no idea why I wrote thisepilectrolytics wrote: ↑Sat Dec 29, 2018 1:18 pmI got this stripe pattern when using BidirVCM with sobol sampler in LuxCoreUI.
I have fixed the code to use BIDIRCPU instead of BIDIRCPUVM (i.e. a not supported render engine).
@photonbuzz2: as workaround, you can just switch render engine using the "Engine" menu or replace the line:
SurfaceIntegrator "bidirectional"
SurfaceIntegrator "path"
It works, when selecting any Engine but BIDIRVMCPU in the GUI. Changing SurfaceIntegrator "bidirectional" to SurfaceIntegrator "path" in the .lxs file throws the error:
RUNTIME ERROR: Unknown render engine type in RenderEngine::ToProperties(): PATHOCL
Why does FreeCAD exports a .lxs file when all examples in the scene directory are built around a .cfg file where the geometry are stored in separate .ply files? Are there any special advantages using a .lxs file?
The FreeCAD exporter seems to be very old.photonbuzz2 wrote: ↑Sat Dec 29, 2018 9:00 pm Why does FreeCAD exports a .lxs file when all examples in the scene directory are built around a .cfg file where the geometry are stored in separate .ply files? Are there any special advantages using a .lxs file?
LXS was the file format of the old LuxRender, while CFG/SCN are the formats of the new LuxCoreRender.
If you want a modern exporter, you could transfer your models into Blender and use the BlendLuxCore addon.
