found the problem :
Nvidia Titan black render :
AMD R9 390 render :
DLSC Explained
Re: DLSC Explained
Uh, that looks like a driver bug, you could try to check if there is an updated version (but I'm not sure if the 390 driver is still updated/maintained ).
Re: DLSC Explained
Updated to the lastest driver don't fix it . anyway i move forward probably at some point a driver could fix .Uh, that looks like a driver bug, you could try to check if there is an updated version (but I'm not sure if the 390 driver is still updated/maintained ).
Re: DLSC Explained
So these splotches are come from a driver problem?
- FarbigeWelt
- Contact:
Re: DLSC Explained
Looks like I have the same amd driver issue with the bathroom scene. I can check this evenig with the scene here.
MacBook Air with M1
MacBook Air with M1
- FarbigeWelt
- Contact:
Re: DLSC Explained
I can confirm Sharlybg's scene shows the lots of splotches if rendered on GPU. The splotches do not show with CPU only,
MacBook Air with M1
MacBook Air with M1
