DLSC Explained
Re: DLSC Explained
Post by Sharlybg » Mon Dec 03, 2018 7:33 pm
found the problem :
Nvidia Titan black render :
AMD R9 390 render :
Re: DLSC Explained
Post by Dade » Mon Dec 03, 2018 8:16 pm
found the problem :
AMD R9 390 render :
Uh, that looks like a driver bug, you could try to check if there is an updated version (but I'm not sure if the 390 driver is still updated/maintained :?:).
Re: DLSC Explained
Post by Sharlybg » Tue Dec 04, 2018 12:02 am
Updated to the lastest driver don't fix it . anyway i move forward ;) probably at some point a driver could fix .
marcatore
Re: DLSC Explained
Post by marcatore » Tue Dec 04, 2018 7:47 am
So these splotches are come from a driver problem?
Re: DLSC Explained
Post by FarbigeWelt » Tue Dec 04, 2018 8:13 am
found the problem :
AMD R9 390 render :
Looks like I have the same amd driver issue with the bathroom scene. I can check this evenig with the scene here.
Re: DLSC Explained
Post by FarbigeWelt » Tue Dec 04, 2018 11:19 pm
I can confirm Sharlybg's scene shows the lots of splotches if rendered on GPU. The splotches do not show with CPU only,
