Hi
When setting up an Emission Material (ID) with the Compositor, it all works fine without clamping. But when I set the Suggested Clamp Value, then it doesn't appear to work at all?
Thanks
Clamp/Emission Material/Compositor
Re: Clamp/Emission Material/Compositor
Scene and/or some screenshots please
Looks like the suggested clamping value is too low.
Try higher values.
Also, you might have to lower your glare thresholds in the compositor a bit if you use clamping.
Try higher values.
B.Y.O.B
Thanks, I'll try that out later today.
B.Y.O.B
Is there a best amount of time rendering to set the Suggested Clamp Value. It appears to change a little bit over time?
No, it is estimated once after 10 seconds.
In the most recent code it was changed to run once after 2 samples I think.
Hi B.Y.O.B
I seem to have been fighting against myself/a typical Catch 22:
Up the light strength to drive compositor, but to reduce the fireflies I have to clamp, and just when the fireflies are gone then so are the compositor effects, so I up the light strength etc etc......
And the above has been the same whether I use a Material ID or the Light group in the Compositor.
That was the bad news. The good news, which appears to be working great, is to render the scene (clamped) then render the effects (not clamped) then mix the two together!
