Is it possible to change the Halt Conditions from 10s in Viewport Rendering?
Sorry if this has been mentioned already ...
Halt Conditions
Halt Conditions
Win10-64bit, Intel i5, GeForce 1060, Blender 2.79, LuxCore v2
Re: Halt Conditions
Yes, display panel in the render tab:
Re: Halt Conditions
Hi
Thanks for the reply - I am using luxcorerender-v2.0alpha1-win64-opencl with the latest BlendLuxCore-win64-opencl.
I have tried Blender 2.79 and 2.78c and under the Render section I have a LuxCore Halt Conditions section for Time and Samples.
I remember the panel you are referring to from LuxRender v1.
Re: Halt Conditions
Update your BlendLuxCore addon: http://wiki.luxcorerender.org/BlendLuxCore_Installation
The panel is called "LuxCore Display Settings", as you can see in the screenshot (not halt conditions).
Re: Halt Conditions
... got it now.
Sorry about the mix up.
It's good to be working with LuxRender again ...
Re: Halt Conditions
No problem. I get the feeling that I should put the viewport halt time to the final render halt conditions, it's probably more intuitive to look there first.
