cannot activate lux render
Anthony O
Re: cannot activate lux render
Post by Anthony O »
it works now! i renamed the 2.79 folder so i guess some other addon in the past did indeed f up my pythonpath ^^ thx alot for the help guys!!!!
Great to hear that!
I hope restoring the other addons is not too much work, and I look forward to see images rendered by you in the forum :)
marcatore
Post by marcatore »
I have problem activating LuxCore (@home).
I've downloaded some days ago one of the latest 2.79.6 builds from Blender.org (date fo build 27th of October).
I've tried to install the 2.1 beta1 and I have this error when I try to activate it.
Modules Installed () from 'H:\\SCRIPTS\\Blender\\RenderEngine\\LuxCore\\BlendLuxCore-v2.1beta1-win64-opencl.zip' into 'C:\\Users\\USERNAME\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons'
  File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\modules\addon_utils.py", line 351, in enable
    mod = __import__(module_name)
  File "C:\Users\USERNAME\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\__init__.py", line 23, in <module>
Exception:
Could not import pyluxcore.
You probably forgot to install one of the redistributable packages.
They are listed in the release announcement post.
ImportError: DLL load failed: Impossibile trovare il modulo specificato.
I've tried to install all the packages requested but it still doesn't work.
Any ideas?
Nightly official blender builds are "supported"?
Anyway I remember to had problems both with official 2.79b.
What I can't really understand is why at work it works.
acasta69
Post by acasta69 »
Luxcore will not work with a Blender "nightly" build because of the different python version. You have to use the official 2.79b.
If you need to use the nightly build and you want to build luxcore yourself, then you can link it against Python 3.7:
just follow the instructions here, but build using the command:
.\cmake-build-x64.bat /python37
marcatore
Post by marcatore »
Thank you for the info.
Actually, installing 2.79b it loads correctly Luxcore.
Nice.
