But remember that you need to keep the addon and the binaries in sync.
If you only update the binaries, or only update the addon, you will run into trouble.
You can download the latest BlendLuxCore from this link:
https://github.com/LuxCoreRender/BlendL ... master.zip
Azure pipeline building, tasting and releasing
Re: Azure pipeline building, tasting and releasing
Thanks, that was close, haha... I'm in the middle of rendering finals for my first luxcore project switching versions...B.Y.O.B. wrote: Fri Oct 26, 2018 2:38 pm But remember that you need to keep the addon and the binaries in sync.
Anyways, So I copied over the latest blendluxcore master you gave link to, and then copied over luxcore pyd from the link from dade (openclwin64). That should be it right? Latest master from blendluxcore and latest win64ocl build from azurebuilds?(luxcore.pyd)
Still says alphav4 so I only guess it went well, seems to be working...
You have to copy all files that are listed here: https://github.com/LuxCoreRender/BlendL ... ses.py#L14
(obviously only the ones for your OS)
The version is only updated shortly before a release.lacilaci wrote: Fri Oct 26, 2018 2:50 pm Still says alphav4 so I only guess it went well, seems to be working...
Well I only copied luxcore.pyd and it works, I'll do the others later.B.Y.O.B. wrote: Fri Oct 26, 2018 3:13 pm You have to copy all files that are listed here: https://github.com/LuxCoreRender/BlendL ... ses.py#L14
Wait why do i need those libraries? Like openimage.dll do they really get updated that often?
No, not really, they have been updated between v2.0 and v2.1 but it s a quite rare happening.lacilaci wrote: Fri Oct 26, 2018 3:43 pm Wait why do i need those libraries? Like openimage.dll do they really get updated that often?
So everything seems to work well from those builds. Automated downloader in the addon would be great.
