Noob Here
a error
lux version latest 2.1 alpha4
following 0ptions not showing
:experimemtal feature set
:materials only editable in nodes
:external api not showing
:convert cycles scene and materials not showing
even in search option
<blockquote class="imgur-embed-pub" lang="en" data-id="a/Xkn1SKz"><a href="//imgur.com/Xkn1SKz"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
LuxCore Experimental and api option not showing
Re: LuxCore Experimental and api option not showing
All this stuff was part of the old LuxBlend addon.
I have rewritten the whole addon from scratch, so it is a new addon called "BlendLuxCore".
The new user manual is here: https://wiki.luxcorerender.org/Category:BlendLuxCore (not complete)
Tutorials can be found here: https://wiki.luxcorerender.org/LuxCoreRender_Tutorials
i habe newest versionB.Y.O.B. wrote: ↑Wed Oct 03, 2018 2:42 pm All this stuff was part of the old LuxBlend addon.
Now i understand you. On the youtube channel there are tutorial for both old luxrender 1.7 and new Core engine Luxcorerenderer. So the 2 last tutorial and upcomming one are only dedicated to Luxcore 2.1 alpha.x wich didn't have same feature as old luxrender 1.7.
luxcore support shading only by node ( wich is the fastest way).
Api 1x and Api option you see in the tutorial are from old lux.
So why you ask this question on a Tutorial where didn't see such option ? (a bit confusing )
what about experimental featureSharlybg wrote: ↑Fri Oct 05, 2018 3:38 pm Now i understand you. On the youtube channel there are tutorial for both old luxrender 1.7 and new Core engine Luxcorerenderer. So the 2 last tutorial and upcomming one are only dedicated to Luxcore 2.1 alpha.x wich didn't have same feature as old luxrender 1.7.
how do i render in external api
in ur newest vid of cycles to lux
ur lux is different than my lux
I simply use Luxcore 2.1 alpha 4 in the new video . go to the news section of the forum to download it .what about experimental feature
The new addon only offers what was previously called the "experimental API" (i.e. LuxCore).
It is no longer "experimental".
Thanks
i m noob at this
my doubts are solved
how do i close this topic or let it continue
i have no money how do i support lux render?
i can code some lamguages
or any thing more
Yes of course Developer are welcome !i have no money how do i support lux render?
or any thing more
