Test scences GPU Path vs CPU BiDir
Glossy Transluscent, correctum
Post by FarbigeWelt » Fri Oct 05, 2018 6:37 am
Sometimes a step back helps to fix issues.
I ran once again into 0815 issue, normals pointing into the wrong direction as it happens after common extrude.
Why glossy behaves differently regarding specularity if normals are wrong, but who knows?
Still, I think specularity is too good visible even set to 0.007. But then, sun is very bright and the behviour is pretty sure correct.
Glossy TL and Glossy comparison
Test Joined Mesh simple.blend
Test Joined Mesh simple with corrected normals
(675.96 KiB) Downloaded 83 times
160.8 | 42.8 (10.7) Gfp / Windows 10 Pro, intel i7 4770K@3.5, 32 GB | AMD R9 290x+RX 5700 XT, 4/8 GB
Irregular Data Node, GPU Path vs CPU Path
Post by FarbigeWelt » Fri Oct 12, 2018 7:48 pm
Intended to help me understand DLC settings, I found a scene setup to visualize differences between CPU Path and GPU Path, not to mention their difference to CPU BiDir.
Instead of using Irregular Data node for Emission of a Matte object, I pluged it into Transparancy of a Glass object with a point lamp inside as base shape for LED bars.
CPU BiDir, CPU or GPU Path, LED with Irregular Data
Test DLC.zip
Test DLC
(795.42 KiB) Downloaded 58 times
Caustics from a Cube
Post by FarbigeWelt » Sun Oct 14, 2018 8:45 pm
Cube, CPU BiDir, depth 10, 100 Samples, 49m, denoised 0.25
Acutally I'm looking for settings for an ice cube.
Re: Irregular Data Node, GPU Path vs CPU Path
Post by Dade » Sun Oct 14, 2018 10:14 pm
A path tracer is not able to transport a point light source across a specular (i.e. glass) surface. You have to use architectural glass. BiDir is able and it is explain the difference.
Post by FarbigeWelt » Tue Oct 16, 2018 10:28 am
Thanks for explanation, Dade.
But it does not explain why DLC circle artifacts are visible with GPU path but not with CPU path.
Post by Dade » Tue Oct 16, 2018 11:43 am
What circle artifacts ? In the posted image :?:
Post by FarbigeWelt » Tue Oct 16, 2018 1:21 pm
Please have a look at the pictures below Edit in:
viewtopic.php?f=5&t=430&p=6682#p6682
Post by Dade » Thu Oct 18, 2018 8:56 am
This is usually the result of some "incorrect" entry (like a light is not visible while it is) in the cache. It can happen if a light is hard to find and, with the default warmup period of only 12 samples, it ends to result always in shadow. The solution is to increase the "lightstrategy.entry.warmupsamples" parameter up to the point artifacts disappear.
CPU GPU Path
Post by FarbigeWelt » Mon Nov 12, 2018 7:34 am
Point Lamp, default w,r,g,b
Glass, rough 1.2
Text matte, emission: 1,10,5
Because of noise level and different distribution of noise (why, it is the same seed?) I smoothed the imgages with a gauss filter.
One can see there is not much difference between CPU and GPU path for this simple scene if its renders are smoothed.
Noise, Path and BiDir or what are Samples?
Post by FarbigeWelt » Tue Dec 11, 2018 7:16 am
If I need 7000 path samples to achieve a similar result I get wth 100 BiDir samples, what is sample count for?
Three Monkeys and their Noise, openCL study
The Monkeys and their Noise, indirect only, clamped, HD, BiDir, 100 samples, 15min.png
The Monkeys and their Noise, indirect only, clamped, HD, BiDir, 100 samples, 15min, BiDir one shot
Indirect Light ,denoiser.zip
Indirect Light, denoiser
(235.13 KiB) Downloaded 58 times
