You are using some extreme setting for the denoiser, in particular, using a 12 search radius window makes everything veeeeery slow. Anyway, it works fine here with the default denoiser parameter:Dez! wrote: ↑Tue Oct 02, 2018 4:29 am https://mega.nz/#!sgQHCKgY!A7OcgHh7zsUW ... vHNu_rBD2M
In this scene (project), if you remove the World - there will be an error of a denoiser
I'm still unable to understand if there is a problem or not.
