Preparing some outdoor furniture...
BTW having some issues with DLCS and sun&sky... present in alphav3 and also v4.
Laci's wip
Re: first steps
more furniture preparation
PS: cloth shader is incredibly slow to render compared to rest, should I just avoid it?
Re: first steps
It is quite complex and likely to be slow especially on GPUs, if it is not the main subject of the rendering, it may be better to use a simpler solution.
Re: first steps
Yeah I will probably stay away from cloth shader unless doing some product viz.
Re: first steps
experimenting with postproduction using krita..... really bad banding in the sky, there is some issue importing tif to krita apparently
Re: first steps
Krita uses 32bit per channel. As suggested should solve the problem
Re: first steps
It wouldn't let me import 16 bit tiff (from blender)... gonna try exr
Re: first steps
Ok, exr works, not sure why tif doesn't...
