One of my friends made an update of a 3D robot with a green laser for engraving wood, plastics or leather. It works well based on diffrent open source drivers and software. He sent me a picture showing the beam and its reflections through transparent, coated glasses. Give me a try, I said, I can simulate a similar picture with the very great luxcorerender blender addon.
I've tried different approaches but run always into the same issue. Luxcore does render lights through glasses resp. mirrors them very slowly. Because one cannot see a ray in clear air, I've set up the whole scene with a homogen, slightly scattering volume. The scattered beam is good visible with BiDir only.
Why is a scattered beam not visible with the path render? Why does sun light not pass through glass but diffuse HDRI or sky light passes with path render? Do this questions have a connected reason?
Decided to use BiDir for my test setup, I placed a glass cuboid between scattered beam and camera. It took a few hundereds samples to get a visible scattered beam but even 1600 samples haven't been enough to get a straight, unbroken line. Maybe, I thought, homogen volume for the whole scene isn't appropriate.
I've setup the scene attached after lots of different tests. The scene, clear volume, contains a cuboid made from Null with homogen, slightly scattering volume. In the background there is a mirror in place. In the foreground there is a glass covering parts of the scene. And there is also a cuboid made from matte placed behing the glass. All materials but the matte have a faint, different color to make them visible. The color is faint enough to avoid much absorption of the scattered beam. The glass under this observation has a reflection of 0.0.
The attached scene shows within the first hundred samples an object made from matte is rendered fast if seen through an object made from glass or mirrored from an object made from mirror, but the scattered beam takes hundreds of samples.
I've tried sobol, metropolis and random, all leading to similar performance.
Is there any good reason for the slow rendering of scattered beams seen through glass or mirrored?
Luxcore renders light through glass very slowly
- FarbigeWelt
- Contact:
MacBook Air with M1
MacBook Air with M1
Re: Luxcore renders light through glass very slowly
I have perhaps related issue with slow sampling through archi glass and non archi glass.
I set the sun size 10x and sun gain 10x and 60W light bulb inside room is overpowering the sun with linear tonemapper.
Sun comes in from another openings by reflecting from another surfaces, but not through glass.
This light that is directly visible to camera from HDR map, comes through fast.
Even BiDirVMcpu 16000 + MLT 36768 + DLC can not find sun that is not directly visible to camera.
Random path is more effective especially in homogeneous volume, but the samples from 200 poly mesh emitter 60W bulb in room, are overweighting sun samples through archi glass which at some gain levels is recommending clamping values in 100 digits.
- FarbigeWelt
- Contact:
Sobol hides sun light through glass
With CPU BiDir, Sobol sun light does not pass through glass in some circumstances. To find the source in the scence leading to this effect took a while to be found. With CPU BiDir, Metropolis sun light passes through glass in the same circumstances. Also interesting CPU Path, Metropolis works too, but GPU doesn't.
Source of effect and abstracted scene following.
MacBook Air with M1
MacBook Air with M1
- Supporting Users
sds paths are notoriously hard to render, and metropolis light transport is a very timed algorithm for this very situation.
Can you post an image of what you want to reach?
I got this: In interior design often I totally remove the window glasses. Often I don't need reflections or I just mix transparent with glossy using a fresnel.
- FarbigeWelt
- Contact:
EDIT: Replaced pictures and scene with colored surrounding, added examples for Path.
In the scene the effect started with a plane surrounding the room outside. In the abstracted scene there still passes some light through the windows with Sobol but in the wooden room scene not. My solution for the moment is to switch windows' glass to architectural. But I rather would like to know if this behaviour of Sobol and Random is usual or even expected. The glass windows have all an offset to show the border of the glass. There is also a different light pass through the thin gap below the glasses, which have a different thickness. Why is there a difference between for the different thickness? Again, there is the difference of CPU and GPU Path for Metropolis. Would be nice if GPU und CPU Path behaved the same way.
MacBook Air with M1
MacBook Air with M1
- FarbigeWelt
- Contact:
Re: at rickyx, reason for investigation
Well, my idea was to setup a fog chamber for tracing beams. But the beams haven't been visible through the glass of the chamber. Then I started to investigate this behaviour viewtopic.php?f=2&t=474&start=120#p5737 what lead finally to the test scene "Renders Glass very slowly".
I think the glass windows issue is related to my earlier observations. This is why I resumed this thread.
MacBook Air with M1
MacBook Air with M1
The issue on the window shelf is caused by geometry.
Tracing through glass is painfully long everywhere, that's just the nature of these engines.
This is where RTXs are supposed to fill the gap. Or PoverVR previously, but nobody cared... or did Apple...?
Personally, i favored SPPM above all (in my tests even VCM & UPBP didn't came close). It had everything going really well except, it was unintuitive to set up, as right settings are totally dependent on the scene (each scene needs different setting, which today could be solved with the help of Ai). But still, even if too complex for an average mind, it was ported to GPU (in academia/university)... and then forgotten, abandoned... and I can only imagine what would become of it with ingenious minds at work with today's tech advancements...
& Here's 10min render on 9 year old machine - 2x xeon X5650 (22 threads @ 2.67 GHz)
Number of glass panels (3mm thick) - from left to right: 0, 1, 2, 3. PS. disregard time (dinner & chit-chat in between)
