Luxcore 2.1 Benchmark
Dez!
Re: Luxcore 2.1 Benchmark
Post by Dez! » Fri Sep 14, 2018 4:20 am
Sprocket wrote:
Fri Sep 14, 2018 12:49 am
4 min, 46 sec on four 7950's.
:o :o :o
32 min 49 sec on GTX 1050M
Linux Gnome | Dell Inspiron 7000 | Wacom
Post by B.Y.O.B. » Fri Sep 14, 2018 6:45 am
jensverwiebe wrote:
Thu Sep 13, 2018 5:36 pm
EDIT3: checked over, the white composite comes from disabling denoise, one must reconnect the renderlayer with plain color output then
( or reenable denoise )
Thanks for investigating.
marcatore
Post by marcatore » Fri Sep 14, 2018 6:48 am
I've tried disabling "compositing" in the post process render settings and actually it renders correctly.
If I re-enable it it turns out full white.
Post by Sharlybg » Fri Sep 14, 2018 6:54 am
With Rx 580 this time will be splited into 3.
Just go back to compositor and connect render layer node to the rest of the node tree.
In fact it happen when you disable denoise so as denoise input no longer exist in your compositing your render turn in white. You can also view your render in raw version by switching between compositing/denoised/renderlayer in render view.
Post by kintuX » Fri Sep 14, 2018 2:28 pm
Some more study on this scene - analysis done, then playing for a bit.
BTW... "License & registration, please!"
8-)
Post by B.Y.O.B. » Fri Sep 14, 2018 8:42 pm
See https://github.com/LuxCoreRender/LuxCor ... OPYING.txt
Dez!
Post by Dez! » Sat Sep 15, 2018 3:05 am
With Rx 580 you can not do it any minute ;)
Post by kintuX » Sun Sep 16, 2018 1:19 pm
Finally, results:
OCL Path
00:07:25.94 - GTX 1060 6GB + Q M5000 8GB + 2x xeon X5650 (24 threads @ 2.667 GHz)
00:09:05.62 - GTX 1060 6GB + Q M5000 8GB
00:15:13.79 - GTX 1060 6GB
00:16:03.29 - Q M5000 8GB
CPU Path
00:37:04.52 - 2x xeon X5650 (24 threads @ 2.667 GHz)
05:12:10.11 - SurfacePro3 i5-4300U 8GB (4 threads @ 1.9GHz)
Post by FarbigeWelt » Tue Sep 18, 2018 7:15 am
00:07:28 OpenCl AMD R9 290x R9 390x
Microsoft Windows 10 Professional, intel i7 4770K, 32 GB, AMD R9 290x 4 GB, AMD R9 390x 8 GB
Instagrammer, please join #luxcorerender for your renderings.
Post by B.Y.O.B. » Fri Oct 05, 2018 3:45 pm
I have updated the zip archive with these changes:
https://github.com/LuxCoreRender/LuxCor ... 51618e9ca9
I also updated the reference image in the first post, hope that's ok.
