volume scatter material
can anyone help me?i just watched a tut of lux render and it had volume scatter shader.but I just downloaded the luxcorerender engine I can't find the volume scatter shader.i use version 2.0.if you found it post a screenshot.if it is not there please add it.thanks.
Re: Help!!!!!!!
Click Add button to add a pointer
Click the drop to change volume parameters
Hi! The volume scatter shader hasn't been ported to LuxCoreRender. For what reason do you need it? You could achieve the same with a 'Null' Material and a homogeneous scattering volume. The volume can be added with the 'add' button next to the interior volume input in the output node as FiatLux wrote.
Re: volume scatter material
any idea on when it will imported.cuz I badly need to make clouds...
We can read your messages even if the text is not bold.
The scatter material is not good for making clouds.
Use a null material with interior volume.
Use a hetereogenous volume.
Texture the scattering color with a volumetric texture, and raise the scattering scale.
Or: use the Blender smoke simulator.
- Attachments
- example.blend
- (1.58 MiB) Downloaded 358 times
Thank you for helping. ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Making realistic clouds is a very complex task.
I think we could give better tips if you describe more closely what you plan to do: Do you need the clouds as background objects far away, or is a plane flying through them and they need a lot of detail? Do they need to be animated? etc.
a lot of detail and slightly needed to be animated
Oh and also I always get an error when I save blender and the open it again later .in the nodes there is an error message saying"undefined socket type" and it automatically switched to blender render and in the rendering engine's list I cant find luxrender. sorry, I am a newbie.
Blender 2.79b ?Waterbottle wrote: ↑Thu May 17, 2018 12:08 pm Oh and also I always get an error when I save blender and the open it again later .in the nodes there is an error message saying"undefined socket type" and it automatically switched to blender render and in the rendering engine's list I cant find luxrender. sorry, I am a newbie.
