LuxCoreRender v2.0beta3 released
jgrover110
Re: LuxCoreRender v2.0beta3 released
Post by jgrover110 »
B.Y.O.B. wrote: Tue Apr 17, 2018 1:19 pm
jgrover110 wrote: Tue Apr 17, 2018 1:10 pm Pressing Ctrl-Z seems to delete all of my material nodes for all materials. This isn't normal, is it? :?
No. Can you open an issue about it, describe in more detail what you did, if it is reproducible, and post an example scene that shows the problem?
The issue isn't scene or context specific. If at anytime I press Ctrl-Z to undo a transform, value edit, or anything else my material nodes get wiped. I have tested the beta2 and 3 on 2.79a Windows 10 (64-bit)
Issue opened
EDIT: Have tested in 2.79b and the problem still occurs
jgrover110 wrote: Tue Apr 17, 2018 1:41 pm
Issue opened
This remembers a bit the save/load bug in Blender 2.79 (fixed in Blender 2.79a).
No such (ctrl+Z) bug here (win7, blender 2.79b-pigeon)
Edit:
Has anyone noticed a difference between CPU & OCL in HDRI light intensity (using Light groups):
Am investigating further...
EDIT - NOT A BUG!
After further investigation (Made a fresh scene, reproduced same settings.) it turns out OCL & CPU return equal results:
I've a ctrl +z bug that crash blender . it happen mostly on my W10 machine but randomly on my office W8 desktop.
Bidir plus clamp lead too bright pixel ( mesh light) :
clamp
no clamp
Dade wrote: Thu Apr 19, 2018 12:09 pm It has already been fixed here: http://forums.luxcorerender.org/viewtop ... =320#p3130
ah Ok , just though wasn't the same as i saw IES related issues (sure i miss something while reading). anyway thank for the pylux file update. ;)
Please do you know if theses issues about material are solved ? a pylux to update ?
https://github.com/LuxCoreRender/BlendL ... issues/131
marcatore
Post by marcatore »
Sharlybg wrote: Thu Apr 19, 2018 12:42 pm
Could you make a test with your scene with the pylux updated?
It seems, in my scene that it's not solved and I'm not using IES file.
marcatore wrote: Thu Apr 19, 2018 1:19 pm
Done and it currently work fine !
Yeah :mrgreen:
