jgrover110
Posts: 47 Joined: Tue Apr 17, 2018 1:07 pm
Post
by jgrover110 » Tue Apr 17, 2018 1:41 pm
B.Y.O.B. wrote: ↑ Tue Apr 17, 2018 1:19 pm
jgrover110 wrote: ↑ Tue Apr 17, 2018 1:10 pm
Pressing Ctrl-Z seems to delete all of my material nodes for all materials. This isn't normal, is it?
No. Can you
open an issue about it , describe in more detail what you did, if it is reproducible, and post an example scene that shows the problem?
The issue isn't scene or context specific. If at anytime I press Ctrl-Z to undo a transform, value edit, or anything else my material nodes get wiped. I have tested the beta2 and 3 on 2.79a Windows 10 (64-bit)
Issue opened
EDIT: Have tested in 2.79b and the problem still occurs
jgrover110 on Wed Apr 18, 2018 7:55 am, edited 1 time in total.
Posts: 5672 Joined: Mon Dec 04, 2017 8:36 pm
Post
by Dade » Tue Apr 17, 2018 2:19 pm
jgrover110 wrote: ↑ Tue Apr 17, 2018 1:41 pm
No. Can you
Issue opened
This remembers a bit the save/load bug in Blender 2.79 (fixed in Blender 2.79a).
Posts: 812 Joined: Wed Jan 10, 2018 2:37 am
Post
by kintuX » Tue Apr 17, 2018 3:12 pm
No such (ctrl+Z) bug here (win7, blender 2.79b-pigeon)
Edit:
Has anyone noticed a difference between CPU & OCL in HDRI light intensity (using Light groups):
Am investigating further...
EDIT - NOT A BUG!
After further investigation (Made a fresh scene, reproduced same settings.) it turns out OCL & CPU return equal results:
kintuX on Tue Apr 17, 2018 5:49 pm, edited 4 times in total.
Posts: 3101 Joined: Mon Dec 04, 2017 10:11 pm
Post
by Sharlybg » Tue Apr 17, 2018 3:17 pm
I've a ctrl +z bug that crash blender . it happen mostly on my W10 machine but randomly on my office W8 desktop.
Post
by Sharlybg » Thu Apr 19, 2018 12:07 pm
Bidir plus clamp lead too bright pixel ( mesh light) :
clamp
no clamp
Post
by Dade » Thu Apr 19, 2018 12:09 pm
Post
by Sharlybg » Thu Apr 19, 2018 12:42 pm
ah Ok , just though wasn't the same as i saw IES related issues (sure i miss something while reading). anyway thank for the pylux file update.
Please do you know if theses issues about material are solved ? a pylux to update ?
https://github.com/LuxCoreRender/BlendL ... issues/131
marcatore
Posts: 463 Joined: Wed Jan 10, 2018 8:04 am
Post
by marcatore » Thu Apr 19, 2018 1:19 pm
Sharlybg wrote: ↑ Thu Apr 19, 2018 12:42 pm
Could you make a test with your scene with the pylux updated?
It seems, in my scene that it's not solved and I'm not using IES file.
Post
by Sharlybg » Thu Apr 19, 2018 1:34 pm
marcatore wrote: ↑ Thu Apr 19, 2018 1:19 pm
Done and it currently work fine !
Post
by kintuX » Thu Apr 19, 2018 1:44 pm
Yeah
