Problems with CUDA in recent versions
74hc595
Post by 74hc595 »
I can't use recent daily LuxCore builds due to CUDA errors:
reloading addon: BlendLuxCore 1607237575.4292386 1607529090.1397486 '/home/1/.config/blender/2.91/scripts/addons/BlendLuxCore/__init__.py'
Modules Installed () from '/home/1/lux_builds/2.5_b1/BlendLuxCore-latest-linux64.zip' into '/home/1/.config/blender/2.91/scripts/addons'
Exception in module register(): /home/1/.config/blender/2.91/scripts/addons/BlendLuxCore/__init__.py
File "/home/1/blender/blender-2.91.0-linux64/2.91/scripts/modules/addon_utils.py", line 382, in enable
mod.register()
File "/home/1/.config/blender/2.91/scripts/addons/BlendLuxCore/__init__.py", line 93, in register
pyluxcore.Init(LuxCoreLog.add)
RuntimeError: CUDA driver API error CUDA_ERROR_UNKNOWN (code: 999, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/core/init.cpp, line: 71): unknown error
I have an older GPU and want to use only CPU for rendering, but LuxCore in Blender crashes with this error immediately upon initialization.
I tried to build from source with flag for disabling CUDA and leaving only OpenCL enabled, but even though CUDA is disabled, I still get an error:
[ 52%] Building CXX object src/slg/CMakeFiles/slg-core.dir/engines/oclrenderengine.cpp.o
/home/1/lux_builds/src/LuxCore-latest/src/slg/engines/oclrenderengine.cpp: In constructor ‘slg::OCLRenderEngine::OCLRenderEngine(const slg::RenderConfig*, bool)’:
/home/1/lux_builds/src/LuxCore-latest/src/slg/engines/oclrenderengine.cpp:128:5: error: ‘CUDADeviceDescription’ was not declared in this scope
128 | CUDADeviceDescription *cudaDesc = (CUDADeviceDescription *)desc;
/home/1/lux_builds/src/LuxCore-latest/src/slg/engines/oclrenderengine.cpp:128:28: error: ‘cudaDesc’ was not declared in this scope; did you mean ‘cudaDescs’?
| cudaDescs
/home/1/lux_builds/src/LuxCore-latest/src/slg/engines/oclrenderengine.cpp:128:63: error: expected primary-expression before ‘)’ token
make[2]: *** [src/slg/CMakeFiles/slg-core.dir/build.make:290: src/slg/CMakeFiles/slg-core.dir/engines/oclrenderengine.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:466: src/slg/CMakeFiles/slg-core.dir/all] Error 2
make: *** [Makefile:103: all] Error 2
Is it possible to build LuxCore for OpenCL only, or even better, for the CPU only?
Update:
I built it without OpenCL and CUDA, but Blender addon still fails to run:
Could not import pyluxcore.
ImportError: /usr/lib/x86_64-linux-gnu/libjemalloc.so.2: cannot allocate memory in static TLS block
Re: Problems with CUDA in recent versions
74hc595 wrote: Wed Dec 09, 2020 4:32 pm I have an older GPU and want to use only CPU for rendering, but LuxCore in Blender crashes with this error immediately upon initialization.
CUDA_ERROR_UNKNOWN is a quite strange error for CUDA and you may have a broken CUDA/driver installation.
74hc595 wrote: Wed Dec 09, 2020 4:32 pm I tried to build from source with flag for disabling CUDA and leaving only OpenCL enabled, but even though CUDA is disabled, I still get an error:
74hc595 wrote: Wed Dec 09, 2020 4:32 pm Update:
You should probably not use jemalloc, it is specific problem of jemalloc/blender/your installation, if you put "libjemalloc cannot allocate memory in static TLS block" in Google you can get some feedback but it is not a problem related to LuxCore: https://devtalk.blender.org/t/problem-w ... odule/7367
74hc595
Post by 74hc595 »
Thank you!
I'll update drivers and give it a try again this evening. I didn't use jemalloc anywhere, but maybe precompiled OIDN is using it. I'll try building it from source too with jemalloc disabled.
74hc595
Post by 74hc595 »
I've tried with most recent version, and it compiles properly with OpenCL support but I still get that jemalloc error, which is weird because when I search the sources for "jemalloc", it occurs literally nowhere, including OIDN.
I updated to most recent NVidia drivers, but still get CUDA_ERROR_UNKNOWN with beta version (maybe it's because I have an old GPU?).
I can't try with daily builds, because there seems to be no Linux build anymore.
acasta69
Post by acasta69 »
74hc595 wrote: Sat Dec 19, 2020 9:22 pm I can't try with daily builds, because there seems to be no Linux build anymore.
Last time the Linux build was not uploaded, most probably because a problem on Azure servers.
A new one should be available in short time.
74hc595
Post by 74hc595 »
Thanks! I'll wait for it, LuxCore is my favourite renderer (especially for volumes and caustics) and I really want to be able to use it again.
Update: I tried newest daily build, but still get CUDA_ERROR_UNKNOWN.
I really wish there was an option to avoid CUDA at all, I only use BiDir cpu renderer anyway.
74hc595 wrote: Sun Dec 20, 2020 10:13 am I really wish there was an option to avoid CUDA at all, I only use BiDir cpu renderer anyway.
Then it is probably used for the film device. You can change that to OpenCL or CPU in the addon preferences.
74hc595
Post by 74hc595 »
I used to do that in earlier daily builds and it worked perfectly that way. In recent builds I get unknown CUDA error when I try to enable addon, so I can't even get to addon preferences and disable it.
74hc595
Post by 74hc595 »
I tried recent daily build and it works perfectly now. It automatically switches to CPU-only.
Thanks for fixing this!
I'll post some new renders soon :)
