Hello,
I'm new in Luxcore more or less, but I'm interested on start to use it for production.
One super important thing to me is Light groups. The other cryptomatte, a pity we don't have it here.
Regarding light groups, I was trying with version 2,4 and was working great but I had to set the composition manually but was working perfectly on interactive. Now I have installed the beta 2,5 b1 and It's making the compositing nodes perfectly but I have no option to change the interactive.
I'm using official blender release 2,91 from steam.
cheers,
Pato.
Light groups
Re: Light groups
This is more or less intended (it's a Blender limitation that the compositor can't be run on a rendered image while rendering is still ongoing).
You will have to wait until the render is done before you can start working with the light groups.
Re: Light groups
Hi B.Y.O.B
Thanks for your answer!
I got that, what I want to say is that before I was able to turn on and off on interactive mode and now it's not possible.
I don't know if that has sense but it was a good quick way to see how groups were affecting the lighting
Thank you,
Pato.
Thank you,
Pato.
Re: Light groups
This is intended. I removed the old light group settings, otherwise the system would have become too unintuitive and convoluted.
Re: Light groups
Hi B.Y.O.B!
Thank you for new auto node for compositor.
But can you please screw back the menu for tweaking light during rendering?
In the corona and vray, LightMix located in the render window, so I think to locate it here would be nice and quite intuitive: Another reason is denoiser at the end works better than in compositor.
Also is it possible to denoise all render layers at the end?
