Displacement Problem
rocknkaya
Post by rocknkaya »
Hi all. I got a problem with displacement problem. How can i fix this? Thanks to all.
Re: Displacement Problem
As far as I remember, you have to set the mesh to smooth in order to not have the faces to "explode" across the sharp edges.
Dade wrote: Sun Dec 06, 2020 11:24 pm As far as I remember, you have to set the mesh to smooth in order to not have the faces to "explode" across the sharp edges.
Can this be automatic as many new people fall into this ?
rocknkaya
Post by rocknkaya »
I try something but its same again. any video of how smooth?
rocknkaya wrote: Mon Dec 07, 2020 8:04 am I try something but its same again. any video of how smooth?
Just right click shade smooth.
Select the object, right click in object mode, choose "Shade Smooth".
Maybe the displacement shape could have an option to treat overlapping vertices as a single vertex during displacement? (Without merging them so the edge still has flat shading after the operation)
rocknkaya
Post by rocknkaya »
Yes. I tried that but not working. How can i do it B.Y.O.B ? Just a new user sorry. Thanks for answer all.
Upload your blend file.
rocknkaya
Post by rocknkaya »
Thank you.
for disp.blend
(1.3 MiB) Downloaded 151 times
DionXein
Post by DionXein »
rocknkaya wrote: Mon Dec 07, 2020 2:05 pmThank you.
You forgot to attach displacement texture.
