Light cut off problem when using Bidir and Metropolis. How to fix?
Marko Posavec
Re: Light cut off problem when using Bidir and Metropolis. How to fix?
Post by Marko Posavec » Thu Nov 12, 2020 2:04 pm
B.Y.O.B. wrote:
Thu Nov 12, 2020 1:48 pm
kintuX wrote:
Thu Nov 12, 2020 1:24 pm
Marko Posavec wrote:
Thu Nov 12, 2020 7:42 am
I tried enabling the auto smooth option under the Object Properties > Normals section, no change.
Note: For time being, it's not implemented for the latest Blender versions - only works with Blender 2.83 LTS :!:
Bypass - Use Edge split modifier.
auto smooth alone should work, only custom normals aren't supported. Or am I wrong?
I didn't get any errors in 2.9 for auto smooth so it probably works? In contrast when I imported a Maya mesh it complained about custom Normals. At first I thought that was the problem. I created this test scene only with blender so custom Normals don't seem to be a problem. Also moments ago I tried with auto smoothing in 283 and it doesn't fix the problem with circular shading artifact on top of the sphere. Still some other problems possible with normals?
Post by kintuX » Sat Nov 21, 2020 8:00 pm
Right you are :D
