Add support for volumetric materials.
Laser + Dust render test.
Re: MaxToLux - 3ds Max Integration for LuxCore
nice work
These are some nice lasers
May the force be with you
are there any builds to test, last one was 0.0.4. and what about the slow performance on bucket rendering, i hope it can be fixed
Amazing work, I can't wait to test new features.
Hi TAO,TAO wrote: ↑Sat May 16, 2020 2:10 pm MaxToLux beta V0.0.4 3dsmax 2019
it's still for test use and not for final production.
https://3dfine.com/down/lux/MaxToLux-Beta v0.0.4.zip
Simple Material Scene.
https://3dfine.com/down/lux/MaterialTest.zip
nice to see that the plugin project for 3ds max isn't dead.
I noticed in the material test image that the testers are all faceted and not smooth, is it on purpose?
thanks
It was a problem with smoothing faces, I already fixed it and in a new build, you can render both smooth and hard surfaces at the same time.
I planed to release new build but there are too many parameters to support and also working with 3dsmax parameters it's a bit time-consuming.
I'll try my best to release a new build soon.
This is the new preview and smooth surface.
You can expect lots of bug fixes, Also, support for almost all the LuxCoreRendere lights, shaders plus camera volumetric effects such as dust.
Still, many parameters left and I'm a busy alone developer.
Tao, that is great!
great job!
great job!
Hi, thank you very much Tao for your work. A simple DOF test after some crash of 3ds max, I was unable to use an HDRI for the environment in any way
Hi Tao, i see the maxTolux is for max 2019.
I'm still on 2018, are you going to release a final version for max 2020/21?
or it will be compatible with the lates max versions?
Hi everybody.
It's been a while.
Good news, I just re compile LuxToMax for 3dsmax 2019 and 2020 and now it will work on 3dsmax 2018 to 2020 perfectlly.
It's been a while.
