spectral rendering
- Theo_Gottwald
Re: spectral rendering
Can you explain the picture?
From my point of view often when i use dispersion, many of the colours are missing and i get just R,G and B.
- MetinSeven
- Contact:
Intriguing. Does this mean that LuxcoreRender yields physically correct dispersion results despite not being a spectral renderer? I'm not very familiar with this field yet.
I think luxcore only have spectral dispersion.MetinSeven wrote: ↑Wed Oct 21, 2020 7:17 amIntriguing. Does this mean that LuxcoreRender yields physically correct dispersion results despite not being a spectral renderer? I'm not very familiar with this field yet.
BTW appleseed seem to have full spectral rendering but i can see the impact on the appleseed gallery.
https://appleseedhq.net/features.htmlSpectral rendering (31 bands in 400-700 nm)
Another way to say this is that LuxCore is not a spectral renderer, but it has two spectral materials, namely Glass and the Thin Film Coating. (Granted, the latter is not a material on its own, but still...)
On each glass interaction, the refraction is calculated with dispersion, then a wavelength-to-RGB conversion is done, and what follows is done again in RGB space. See the example of a possible implication I posted here.
In the source code, I also see some spectral stuff in textures, but I think it is just to precompute RGB data based on physical inputs
- MetinSeven
- Contact:
Looking at the Blenderseed update frequency, I've got the impression that Appleseed is not very alive anymore:
https://github.com/appleseedhq/blenderseed
I also believe that Appleseed is still CPU-only and that there's no macOS support.
Yes this is the precarity of opensource render engine. Even if there is amazing potential weakness catch up and kill everything.MetinSeven wrote: ↑Wed Oct 21, 2020 8:46 amLooking at the Blenderseed update frequency, I've got the impression that Appleseed is not very alive anymore:
This the reason i always say everyone involve in the project should think about way to support :
__ Report Bug
__ Share your Work
__ Donate
__ participate to community life (express your POV)
__ Code even small thing is welcome (addon / core engine)
__ Comment on other Lux work as much as you can on every platform
Don't want to spread fear among but we aren't far from that appleseed current state
- MetinSeven
- Contact:
I think the Luxcore devs are doing a fine job with frequent build updates, improving GPU support and a macOS version.
Yes but all the Core engine stuff is on a single Man since Years now and the addon situation is pretty simillar.MetinSeven wrote: ↑Wed Oct 21, 2020 9:04 amI think the Luxcore devs are doing a fine job with frequent build updates, improving GPU support and a macOS version.
After 3 years of rebirth i don't see any other Developper joinning core engine development.
Userbase is minimal. And even if there 1500 people subscribing to the forum i can count user participating
in the project life.
__Dez
__ MetinSeven
__ Theogottwald
__ Cgvirus
__CodeHD
__Farbigewelt
__b2przemo
__joyasrohrbach
__PDRA
Maybe i forget couple of names but it really doesn't change the picture that much.
It is fixable but not without coordination and communication and clear path definition.
Many are doing a great job exposing and supporting this amazing project but there is lack
of coordination concertation.
- MetinSeven
- Contact:
It'd be great if LuxcoreRender gets more recognized among 3D users. It is a truly great renderer, ahead of Cycles in multiple areas.
Once Luxcore gets more user attention, more donations and interested developers will follow.
