LuxCoreRender v2.0beta1 released
Post by Dade » Mon Apr 02, 2018 12:38 pm
New LuxCoreRender v2.0beta1 release is available at: https://luxcorerender.org/download
v2.0 release notes are available here: https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.0
The complete list of changes between alpha7 and beta1 in Luxcore API is available here: https://github.com/LuxCoreRender/LuxCor ... _v2.0beta1
The complete list of changes between alpha7 and beta1 in BlendLuxCore is available here: https://github.com/LuxCoreRender/BlendL ... _v2.0beta1
This version includes new heterogeneous volume rendering code, a major performance improvement when rendering high resolution images with OpenCL, full light groups support in BlendLuxCore, the first complete version of network rendering support, many fixes and more.
P.S. after a couple of days of testing, if all goes well, this is going to be a the first public release of v2.0 and it will be announced on the old forums and web site. This will end the (not so close) alpha stage.
Re: LuxCoreRender v2.0beta1 released
Post by Sharlybg » Mon Apr 02, 2018 12:59 pm
Congratulation for bringing this dream to reality ! :D
Harvester
Post by Harvester » Mon Apr 02, 2018 1:45 pm
This is a great achievement. Thank you David.
camara
Post by camara » Tue Apr 03, 2018 11:21 am
Congratulations on this release! Going to test it out!
Post by Dade » Tue Apr 03, 2018 2:33 pm
Note: there is a bug in PyInstaller on Linux affecting PyLuxCoreTools (i.e. network rendering). you can find the details here: https://github.com/LuxCoreRender/LuxCore/issues/80
Short version: you can actually use network rendering only on Windows, not Linux.
Post by kintuX » Tue Apr 03, 2018 3:41 pm
Thanks for update :)
Found couple of issues:
1. Glass Rough doesn't work using OpenCL
2. small differences in final results (renderings) between both engines and even using same engine with different devices (IIRC, later one is known bug - different results: CPU vs GPU/OCL (@ LuxRender forum).
e.g.
BiDir (also used as reference for comparison)
Path CPU
Path GPU
BiDir VS Path CPU (difference+gamma2)*
Path CPU VS Path GPU/OCL (difference+gamma2)*
* Used GIMP. Layer Mode: Difference; Gamma upped to 2, to emphasize the difference
Test Scene:
LC_beta001shadersTest.zip
(168.16 KiB) Downloaded 117 times
HDRI: https://www.pingo.nu/s/Office_small.hdr
Asticles
Post by Asticles » Tue Apr 03, 2018 5:56 pm
Thanks for this release!
Salvador Ureña
Post by Dade » Tue Apr 03, 2018 6:08 pm
This bug was a pure concentrate of cut&paste errors: https://github.com/LuxCoreRender/LuxCor ... 2432eaeb3c
The bug you linked has been fixed a while ago. As far as I can see, the PATHCPU and PATHOCL output is exactly the same (once #1 has been fixed).
You should use the .exr for comparison (and gamma 1.0 because it doesn't make sense to me to do a comparison in a non-linear space). Anyway, the output is supposed to be exactly the same only on the long run (i.e. in a noise free render).
Post by kintuX » Tue Apr 03, 2018 6:59 pm
TYVM for corrections & tips. 8-)
Taking notice... testing further...
Asticles
Post by Asticles » Fri Apr 13, 2018 7:10 pm
Thanks for this!
Salvador Ureña
