I transplanted Microfacet Reflection from pbrt to luxcore and the results did not meet my expectations.
I'm using Trowbridge Reitz Distribution.
Why Does LuxCore Not Support the GGX Model?
Re: Why Does Luxcore Support Materials Based on the GGX Model?
Why shouldn't we ?
In case you wanted to ask why "doesn't": current Disney material uses a GGX distribution.
How ? Where ? What does mean "transplanted " ?
How doesn't it meet your expectation ? You need to better explain/show what kind problem you have.
Um, I’m very sorry, there is something wrong with my description
I refer to pbrt to implement class BRDF, class Microfacet Reflection, and then implement the plastic material in pbrt in luxcore
Regarding energy conservation, adding BXDF::f() in pbrt, I think it is not in line with energy conservation?
Sorry, I currently have no way to show my code
The specific implementation is as follows:
1. Use BXDF::f() and BXDF::pdf() in the Evaluate function to calculate bsdfEval and directPdfW
2. Use the BXDF::sample_wh() function in the Sample function to calculate localSampledDir
