Graswald and The Grove - Creating Lux Materials
CEROE
Re: Graswald and The Grove - Creating Lux Materials
Post by CEROE » Wed Sep 02, 2020 12:32 am
GPU rendering in 2.5 not working with Blender 2.83.2 on my machine.
Tried system settings of CUDA, OptiX and OpenCL with different combinations of LuxCore API settings of OpenCL and CUDA. Turned off CPU rendering as well as combination. No luck.
Post by Dade » Wed Sep 02, 2020 1:04 am
You need to update your NVIDIA drivers to 451+.
CEROE
Post by CEROE » Wed Sep 02, 2020 1:09 am
Have version 452.06 installed. Studio version.
CEROE
Post by CEROE » Wed Sep 02, 2020 2:31 am
Rendered again at 500 samples with Denoiser. (Adjusted values for transmissions. Had set most to .500, which dulled the translucency. This one looks livelier.)
Full render is 3480 x 2160 and took 50:36. (My estimated time was wrong previously)
This version is 50% of original in order to upload.
Post by Dade » Wed Sep 02, 2020 11:44 am
How doesn't it work ? Do you get a console error ? A crash ?
CEROE
Post by CEROE » Thu Sep 03, 2020 9:27 pm
It would stay in kernel compiling.
CEROE
Post by CEROE » Fri Sep 04, 2020 6:04 am
Rendered twice with latest build of 2.5.
First render set system to OptiX and add on to CUDA. Rendered in 38:21
Second render set system to CUDA and add on to CUDA with OptiX unchecked. Rendered in 38.04
Post by Dade » Fri Sep 04, 2020 11:05 am
You have rendered both times with CUDA+Optix, the current BlendLuxCore preference setting has no effect (viewtopic.php?f=5&t=2283&start=50#p24699). Try to compare CUDA+Optix Vs. OpenCL.
CEROE
Post by CEROE » Fri Sep 04, 2020 7:53 pm
Yeah, a big difference. With OpenCL it rendered in 53:03
Post by Dade » Fri Sep 04, 2020 9:19 pm
Yes, this is the type of scenes where RTX hardware can make a huge difference.
