Lux animation and ways of it
DionXein
Post by DionXein »
Hello there.
I am not so familiar with luxcore, but lasts releases with render speed performance and using of cuda etc. rise some interests in me. Especially in animation way of it. I don't clearly realize how works roughness (max value is 0.8, but in cycles it 1(?)), but already made some tests. Hope I find other ideas to make another video or expand this one.
(1080p avaible)
https://drive.google.com/file/d/10QW2PY ... sp=sharing
Re: Lux animation and ways of it
Note: the file is not public.
DionXein
Post by DionXein »
Dade wrote: Tue Jun 02, 2020 1:29 pm
Seems google drive change default settings for links access. Now it should work
DionXein
Post by DionXein »
So I tried another animation variant.
https://drive.google.com/file/d/1G35JRR ... sp=sharing
384 frames, 1920x1080, CPU (Ryzen 7 2600), 2 min per frame, OIDN, total render time 13 hours.
Here is some issue with motion blur, shatter is too low I guess. Also if I use only CPU to render, it blocks all features from camera setting such as bloom?
DionXein wrote: Tue Jun 02, 2020 12:42 pm Hello there.
(1080p avaible)
I like this one with the suzane and the animated sun. how long to render and hardware ?
DionXein wrote: Tue Jul 28, 2020 2:59 pm Also if I use only CPU to render, it blocks all features from camera setting such as bloom?
Can you upload a small scene showing this problem?
DionXein
Post by DionXein »
Sharlybg wrote: Tue Jul 28, 2020 3:38 pm I like this one with the suzane and the animated sun. how long to render and hardware ?
I used Ryzen 7 2600 and GTX 2060 3Gb. And I think it took about 2-3 minutes per frame (24fps for cinematic look).
