[LuxRays][464.884] Device 2 name: GeForce GTX 760
[LuxRays][464.884] Device 2 type: CUDA_GPU
[LuxRays][464.884] Device 2 compute units: 192
[LuxRays][464.884] Device 2 preferred float vector width: 1
[LuxRays][464.885] Device 2 max allocable memory: 4034MBytes
[LuxRays][464.885] Device 2 max allocable memory block size: 17592186044415MBytes
[LuxRays][464.885] Device 2 has out of core memory support: 1
[LuxRays][464.885] Creating 5 intersection device(s)
[LuxRays][464.885] Allocating intersection device 0: GeForce GTX 760 (Type = CUDA_GPU)
[LuxRays][464.904] [Optix][4][KNOBS] All knobs on default.
[LuxRays][464.904] [Optix][2][ERROR] Error creating RTX context
File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/engine/base.py", line 86, in render_final
final.render(self, depsgraph)
File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/engine/final.py", line 48, in render
_render_layer(engine, depsgraph, statistics, layer)
File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/engine/final.py", line 60, in _render_layer
engine.session = engine.exporter.create_session(depsgraph, engine=engine, view_layer=view_layer)
File "/home/pepo/buildbot/2.90/scripts/addons/BlendLuxCore/export/__init__.py", line 215, in create_session
pyluxcore.KernelCacheFill(config_props_copy)
RuntimeError: Optix error (code: 7051, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/devices/cudadevice.cpp, line: 155): OPTIX_ERROR_INVALID_DEVICE_CONTEXT
ERROR: Optix error (code: 7051, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/devices/cudadevice.cpp, line: 155): OPTIX_ERROR_INVALID_DEVICE_CONTEXT
Info: Compiling CUDA kernels (just once, takes a few minutes)
The card is not supported in Cuda 11 as far as I know.
I think about to buy a new card anyway but want to know if it cant work, then I stay at Luxcore 2.4.
Thanks, mib
