BlendLuxCore Development
Re: BlendLuxCore Development
I started the work on a light group editor realized as a compositor node group.
It is created with the press of one button in the light group panel and looks like this:
(the denoise node is not yet added by the script, but it will be)
Look awesome and clean.
Can the wide node group mixer in the middle be animated ?
So we can make light animation based on a single render shot by animating light color and strengh along a time frame.
Yes, since it's a regular compositor node group, it can be animated.
AwesomeYes, since it's a regular compositor node group, it can be animated
Pretty cool.
I would add the option to have the denoise inside the node group, per pass, it will deliver better overall result I think.
I don't see how denoising each pass individually would benefit the result. It would certainly decrease the responsiveness of the setup a lot, though.
Can you show images that prove a benefit of denoising individual lightgroup AOVs versus denoising the sum of the AOVs?
I'll try to assemble some example, I'm kind of missing from Discord and the forum because I'm a bit overwhelmed, but I'll see what I can do
Hi BYBO ! Want to know if this node group is available and how enable it.
It is not done yet. It's currently only available in a branch of the addon: https://github.com/LuxCoreRender/BlendL ... oup_editor
