Luxcore always does recompile openCL kernel macOS after macOS restart with the same scene
Windows is fine.
Any idea why for the mac this always needs to be redone?
The compile takes very long and students on macs would be quite turned off by this.
recompile openCL kernel macOS after restart
Re: recompile openCL kernel macOS after restart
Maybe this is some specially configured macOS that wipes itself after restarts?
Or maybe just the kernel cache is created in a directory that is wiped?
/tmp ? Some unix system usually delete everything /tmp after a boot ? Does MacOS delete everything after a reboot ?
Other possible problem may something related write permissions.
The code (https://github.com/LuxCoreRender/LuxCor ... l.cpp#L213) uses boost::filesystem::temp_directory_path(): it is unclear what it is used on MacOS but it may be /tmp.
yeah after each macOS restart it is gone - just tested it again.
Windows is fine.
Windows is fine.
I just find it weird that no other macOS user has ever reported this problem.
That's why I'm wondering if those school/university machines are configured differently than normal (at least I assume we are talking about some kind of school/university machines here, or is it also happening on your personal machine?).
I'm out of the town at the moment I will be back in few days, this should be easy to fix. I can make it configurable to solve the problem at root: just something you can set in BlendLuxCore preferences.
MacOS OpenCL/CUDA kernel cache directory is now created in user home directory (as "luxcorerender.org") to avoid to be erased when in /tmp.
I don't have a Mac to test the new code (but it is Unix code and it works on Linux).
Well guess i never restart my mac.. i'll test the patch
I recompiled so many times so i guess it was normal for me to rebuild the cache every time
portfolio http://q3de.com/
MB Pro i7 2.3Ghz, IrisPro 1.5GB, GTX750m 2GB - BigSur
Xeon X5650@4Ghz, RX 5700 - BigSur , Windows 10, Ubuntu 20.04
All seems to work here i'm not able to reproduce the problem with older build ... but it should work as expected now.
