Reducing roughness by value
lighting_freak
Post by lighting_freak » Thu Jun 25, 2020 9:24 am
Hello all,
what happens if I reduce the roughness value (limit with direct entry is 0,001) with the help of an value node?
Is it possible to reach lower roughness values with this trick?
Thank you.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
Re: Reducing roughness by value
Post by Dade » Thu Jun 25, 2020 9:53 am
It is limited by the code to 1e-9: https://github.com/LuxCoreRender/LuxCor ... y2.cpp#L76
You can export the scene in text format to check how your node setup is exported.
Fox
Post by Fox » Thu Jun 25, 2020 9:58 am
Yes, i use all the time 0.00000001 for glass with BiDirVM + Sun or Sun on HDRmap.
The BiDirVM renders sun black with clear glass.
Post by B.Y.O.B. » Thu Jun 25, 2020 10:52 am
Should I use 1e-9 in the Blender addon as well?
Post by Dade » Thu Jun 25, 2020 10:58 am
I don't think so, 1e-9 is a limit coming from old Lux and it is too small: if you check few line after, there is a square of the number (and than a division too) and it is very likely to end as a 0 with FP32. Using so small numbers is asking for troubles.
Fox
Post by Fox » Thu Jun 25, 2020 11:56 am
1e-8 is lowest that has worked for me.
Are there any other FP32 limitations for volume absorption in small scale rendering, like jewelry?
Like say a gemstone 2mm in size, sometimes you change transmission 2.5 times lower, but it goes from full transparent to pure black?
lighting_freak
Post by lighting_freak » Tue Jun 30, 2020 4:35 am
Thanks for your help.
This one is a good question too.
I had some troubles in the past as well:
BR
OS - Windows 7 X64
CPU - Intel CORE i7
