Honey and raspberry
Utilizator9
Honey and raspberry
Post by Utilizator9 »
Hello! I really liked luxrender, so I think I will completely switch to it. I wanted to do something summer, this is the result.
Re: Honey and raspberry
Nice work thanks for sharing.
the honey pot is extremelly well done very realistics. A side note for improvement could be better shader on fruit ? the Apple a extremelly shiny and raspberry look strange. you can improve it by using lot of reference photo.
Utilizator9
Sharlybg wrote: Thu Jun 25, 2020 10:37 am Nice work thanks for sharing.
Thank you! really missed something.
fxgogo
Post by fxgogo »
Hi like the render a lot. The qualitiy of the light feels very good. Two points I noticed, the close up of the jar, I can see the straight line polygons. It was only in the close up though. The other point is just a tip for all renders. CG is often too sharp and a bit brittle. To give it that photographic look you can start by giving it a slight blur. It sounds wierd, but it helps a lot in making it feel more real. There is a whole world of techniques you can use, but starting with blur is a good.
Well done.
