u3dreal
Posts: 560 Joined: Tue Dec 03, 2019 3:23 pm
Post
by u3dreal » Thu May 28, 2020 9:35 pm
OK i copied ..
libnvrtc.dylib and versions
libnvrct-buildins.dylib and versions
in the luxcoreui dir
i renamed my cuda dir
cuda seems enabled but no cuda device found
[LuxRays][11.197] OpenCL support: enabled
[LuxRays][11.197] OpenCL Platform 0: Apple
[LuxRays][11.198] CUDA support: enabled
[LuxRays][11.198] Device 0 name: Native
[LuxRays][11.198] Device 0 type: NATIVE_THREAD
[LuxRays][11.198] Device 0 compute units: 1
[LuxRays][11.198] Device 0 preferred float vector width: 4
[LuxRays][11.198] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][11.198] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][11.198] Device 0 has out of core memory support: 0
[LuxRays][11.198] Device 1 name: Intel(R) Core(TM) i7-4850HQ CPU @ 2.30GHz
[LuxRays][11.198] Device 1 type: OPENCL_CPU
[LuxRays][11.198] Device 1 compute units: 8
[LuxRays][11.198] Device 1 preferred float vector width: 4
[LuxRays][11.198] Device 1 max allocable memory: 16384MBytes
[LuxRays][11.198] Device 1 max allocable memory block size: 4096MBytes
[LuxRays][11.198] Device 1 has out of core memory support: 0
[LuxRays][11.198] Device 2 name: Iris Pro
[LuxRays][11.198] Device 2 type: OPENCL_GPU
[LuxRays][11.198] Device 2 compute units: 40
[LuxRays][11.198] Device 2 preferred float vector width: 1
[LuxRays][11.198] Device 2 max allocable memory: 1536MBytes
[LuxRays][11.198] Device 2 max allocable memory block size: 384MBytes
[LuxRays][11.198] Device 2 has out of core memory support: 0
[LuxRays][11.198] Device 3 name: GeForce GT 750M
[LuxRays][11.198] Device 3 type: OPENCL_GPU
[LuxRays][11.198] Device 3 compute units: 2
[LuxRays][11.198] Device 3 preferred float vector width: 1
[LuxRays][11.198] Device 3 max allocable memory: 2048MBytes
[LuxRays][11.198] Device 3 max allocable memory block size: 512MBytes
[LuxRays][11.198] Device 3 has out of core memory support: 0
RenderSession starting error:
Hardware device selection string has the wrong length, must be 3 instead of 4
Where does lux look for the libs ??
Posts: 5672 Joined: Mon Dec 04, 2017 8:36 pm
Post
by Dade » Thu May 28, 2020 9:43 pm
acasta69 wrote: ↑ Thu May 28, 2020 7:27 pm
Defining LUXRAYS_DISABLE_CUDA and LUXRAYS_DISABLE_OPENCL seems to have no effect: LuxCoreUI still allows to choose OCL render engines. I'll try to check why this happens.
Yes but it should have no device available at all for the rendering. I guess it could be removed from the menu too.
Post
by Dade » Thu May 28, 2020 9:45 pm
u3dreal wrote: ↑ Thu May 28, 2020 2:22 pm
which files are needed by lux then ??? only the installed driver ?So i will not have to add any .dylib files ?? And no patching
That sounds unbelievable
This will make things alot easier ...
One thing is to compile from the source (nothing is required), another thing is to run the generated executable (drivers and DLLs are required).
u3dreal
Post
by u3dreal » Thu May 28, 2020 9:55 pm
Does that mean cuda libs were found ?
[LuxRays][10.703] CUDA support: enabled
u3dreal
Post
by u3dreal » Thu May 28, 2020 11:25 pm
Does luxcore look in the directory it is in ? or will we have to add that manually .
like @rpath for osx ?
u3dreal
Post
by u3dreal » Fri May 29, 2020 9:37 am
cool adding @executable_path makes luxcoreui work ... so i guess i will just add the other paths for the bundle and pyluxcore ... i guess it uses the same paths Wow that makes the compiling on azure really easy ... just copy the libs ...
[LuxRays][19.683] OpenCL support: enabled
[LuxRays][19.683] OpenCL Platform 0: Apple
[LuxRays][19.683] CUDA support: enabled
[LuxRays][19.683] CUDA support: available
[LuxRays][19.683] CUDA driver version: 10.10
[LuxRays][19.683] CUDA device count: 1
[LuxRays][19.683] Device 0 name: Native
[LuxRays][19.683] Device 0 type: NATIVE_THREAD
[LuxRays][19.683] Device 0 compute units: 1
[LuxRays][19.683] Device 0 preferred float vector width: 4
[LuxRays][19.683] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][19.683] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][19.683] Device 0 has out of core memory support: 0
[LuxRays][19.683] Device 1 name: Intel(R) Core(TM) i7-4850HQ CPU @ 2.30GHz
[LuxRays][19.683] Device 1 type: OPENCL_CPU
[LuxRays][19.683] Device 1 compute units: 8
[LuxRays][19.683] Device 1 preferred float vector width: 4
[LuxRays][19.683] Device 1 max allocable memory: 16384MBytes
[LuxRays][19.683] Device 1 max allocable memory block size: 4096MBytes
[LuxRays][19.683] Device 1 has out of core memory support: 0
[LuxRays][19.683] Device 2 name: Iris Pro
[LuxRays][19.683] Device 2 type: OPENCL_GPU
[LuxRays][19.683] Device 2 compute units: 40
[LuxRays][19.683] Device 2 preferred float vector width: 1
[LuxRays][19.683] Device 2 max allocable memory: 1536MBytes
[LuxRays][19.683] Device 2 max allocable memory block size: 384MBytes
[LuxRays][19.683] Device 2 has out of core memory support: 0
[LuxRays][19.683] Device 3 name: GeForce GT 750M
[LuxRays][19.683] Device 3 type: OPENCL_GPU
[LuxRays][19.683] Device 3 compute units: 2
[LuxRays][19.683] Device 3 preferred float vector width: 1
[LuxRays][19.683] Device 3 max allocable memory: 2048MBytes
[LuxRays][19.683] Device 3 max allocable memory block size: 512MBytes
[LuxRays][19.683] Device 3 has out of core memory support: 0
[LuxRays][19.683] Device 4 name: GeForce GT 750M
[LuxRays][19.683] Device 4 type: CUDA_GPU
[LuxRays][19.683] Device 4 compute units: 192
[LuxRays][19.683] Device 4 preferred float vector width: 1
[LuxRays][19.683] Device 4 max allocable memory: 2047MBytes
[LuxRays][19.683] Device 4 max allocable memory block size: 17592186044415MBytes
[LuxRays][19.683] Device 4 has out of core memory support: 1
Post
by Dade » Fri May 29, 2020 10:20 am
Ok, so it looks like everything is ok, I will merge the branch than we will have to update Azure build process to build only one type of executable.
Post
by Dade » Fri May 29, 2020 10:24 am
Dade wrote: ↑ Fri May 29, 2020 10:20 am
Done.
