MaxToLux - 3ds Max Integration for LuxCore
Re: MaxToLux - 3ds Max Integration for LuxCore
Post by TAO » Sun May 17, 2020 11:21 am
Dade wrote:
Sun May 17, 2020 11:03 am
a1-kh wrote:
Sun May 17, 2020 10:42 am
Wrong number of values in property: scene.textures.Map_1.file
Is there a space in the filename? It should be enclosed in " " in that case.
I already remove all unwanted characters like space, slash, $, or anything like that and replace all with an underline. I don't think that's the case with a long path.
Also already fixed the issue with "," separator. That was really tricky.
Download link to last MaxToLux build.👇👇
viewtopic.php?f=5&t=1010&start=160#p22925
a1-kh
Post by a1-kh » Sun May 17, 2020 11:40 am
Is there a space in file name ? It should be enclosed in " " in that case.
Hi there , no the names are all without spaces
a1-kh
Post by a1-kh » Sun May 17, 2020 11:45 am
TAO wrote:
Sun May 17, 2020 11:09 am
It's a known issue with a too-long image path for textures. When I parse a too long file address in LuxCore it can not find the image file.
I'm trying to fix it.
For now, you can just move your project in a smaller path, for example, d:\temp or such.
Sorry for the inconvenience.
It's a brand new plugin and there are so many things do work on, I'm trying my best.
Let me if this fixes the issue.
Thanks for the tip, yeah it worked after i shortened the path. thanks . i am testing the scene all-settings now .
a1-kh
Post by a1-kh » Sun May 17, 2020 11:50 am
Does the "TILEPATHOCL" setting run on gpu ? cause i see the cpu usage at full with many rendering tiles ?
Post by TAO » Sun May 17, 2020 11:51 am
Thank you for your replay.
Honestly, I don't know whats the issue with the long-path but it's not about 3dsmax and it will happen with luxCore itself.
I'm still investigating the issue.
Is there any bug tracker that we can use to organized bugs and features?
Post by TAO » Sun May 17, 2020 11:53 am
Yes, it works on GPU.
Post by B.Y.O.B. » Sun May 17, 2020 12:02 pm
Honestly, I don't know whats the issue with the long-path but it's not about 3dsmac and it will happen with luxCore itself.
The MaxToLux github repo has an issue tracker.
a1-kh
Post by a1-kh » Sun May 17, 2020 12:03 pm
oh , then i guess "TILEPATHSAMPLER" option on gpu is very slow, or doesn't use the gpu at all.
TILEPATHCPU : 1 minute = 60 samples
TILEPATHOCL : 1 minute = 70 samples ( very small gpu usage based on NVIDIA Inspector ) ( 1 GPU )
TILEPATHOCL : 1 minute = 70 samples ( very small gpu usage based on NVIDIA Inspector ) ( 2 GPU )
any thoughts ?
PS : CPU usage in 3 tests is always 100%
Post by TAO » Sun May 17, 2020 12:04 pm
Thank you.
Post by TAO » Sun May 17, 2020 12:07 pm
any thoughts ?
Can you send me some sort of GPU profiler or anything that shows GPU usage?
