Hi everyone.
I'd like to create a simple script in blender(Python) which creates a glossy shader from script, loading Diff, Rough, Normal textures from specified folder.
In Cycles I'd start with "import bpy ... bpy.data.materials.new(name="NewMaterial"), how can I do for a LuxCore shader?
Simple shaders from python script
Re: Simple shaders from python script
Here's an example:
import bpy
mat = bpy.data.materials.new(name="Material")
tree_name = "Nodes_" + mat.name
node_tree = bpy.data.node_groups.new(name=tree_name, type="luxcore_material_nodes")
mat.luxcore.node_tree = node_tree
# User counting does not work reliably with Python PointerProperty.
# Sometimes, the material this tree is linked to is not counted as user.
node_tree.use_fake_user = True
# Add nodes to the node tree
nodes = node_tree.nodes
output = nodes.new("LuxCoreNodeMatOutput")
output.location = 300, 200
output.select = False
glossy2 = nodes.new("LuxCoreNodeMatGlossy2")
glossy2.location = 50, 200
node_tree.links.new(glossy2.outputs[0], output.inputs[0])
# Load image, for docs on this see https://docs.blender.org/api/current/bpy_extras.image_utils.html#module-bpy_extras.image_utils
import bpy_extras
diffuse_img = bpy_extras.image_utils.load_image("/home/simon/Downloads/diamond_CPU.jpg")
# Create imagemap node
diffuse_img_node = nodes.new("LuxCoreNodeTexImagemap")
diffuse_img_node.location = -200, 200
diffuse_img_node.image = diffuse_img
node_tree.links.new(diffuse_img_node.outputs[0], glossy2.inputs["Diffuse Color"])
# Assign to object (if you want)
obj = bpy.context.active_object
if obj.material_slots:
obj.material_slots[obj.active_material_index].material = mat
else:
obj.data.materials.append(mat)
# For viewport render, we have to update the luxcore object
# because the newly created material is not yet assigned there
obj.update_tag()
Wonderful!!!!
Thank you very, very much!!
Ok, This is the result of my script! Last question: How can I change the colors of slots?
I've tried "ramp_node.ramp_items[0].ColorRampItem = (0.4,0.2,0.0)" but it didn't work.
You should use gamma = 1 for the roughness map.
Like this:
Now it works! Thank you so much!
Why? Always in B/W map?You should use gamma = 1 for the roughness map
Reverse gamma is always applied to any image map (gamma = 1.0 is indeed a null transformation) because the rendering is than supposed to be gamma corrected. Otherwise you would end with gamma correction applied two times to texture maps.
Ok! Quite difficult to understand for me! I'll study gamma much better! Thank you Dade
