Thin-film Interference
I have added support for thin-film interference to the following materials:
  • Glass
  • Arch. glass
  • Rough glass
  • Disney
It can be used for oil slicks, soap bubbles, oxid layers on heated metal, car paint, anti-reflective coatings, beetle carapace etc.
The resulting colors depend on the thickness of the film, the refractive index of the film, and the angle between surface and viewer.
BlendLuxCore
In the Blender addon, the "glass" and "disney" nodes now have a "Thin Film Coating" checkbox.
If enabled, you can specify the thin film thickness (in nanometers) and the IOR of the coating material with two new sockets.
On the disney node, there is an additional "Film Amount" socket so you can mix in more or less of the film effect.
LuxCore SDL
The textures to control the film appearance are defined with the properties
scene.materials.<material name>.filmthickness = 300  # in nanometers
scene.materials.<material name>.filmior = 1.5
The disney material has the additional property
scene.materials.<material name>.filmamount = 1
which is the linear interpolation factor between no film and film.
u3dreal
Re: Thin Film Interference
Post by u3dreal »
Looks really awesome !!! :o
portfolio http://q3de.com/
MB Pro i7 2.3Ghz, IrisPro 1.5GB, GTX750m 2GB - BigSur
Xeon X5650@4Ghz, RX 5700 - BigSur , Windows 10, Ubuntu 20.04
lacilaci
Post by lacilaci »
Yup, this is a fantastic addition. :D
JoeDDD
Re: Thin-film Interference
Post by JoeDDD »
B.Y.O.B. wrote: Mon May 11, 2020 5:39 pm I have added support for thin-film interference to the following materials:
  • Glass
  • Arch. glass
  • Rough glass
  • Disney
Would it be possible to add film option also to anisotropic metal shader? Because the disney anisotropic works kinda weird and has less options.
Great addition btw!
Weldone.
Which revision could I use so I can add thin-film interference to MaxToLux?
You will need the latest daily build of LuxCore.
Fox
Post by Fox »
Very cool feature, thank you.
I tested this out on my camera scene:
