From .flm to .exr or .png16bit
Re: From .flm to .exr or .png16bit
pyluxcoretools merge now supports saving film AOVs via new --aov-output option, for instance:
The AOVs names can bee seen here: https://github.com/LuxCoreRender/LuxCor ... md.py#L147
david@Desktop-3900x:~/projects/luxcorerender/LuxCore$ python3 lib/pyluxcoretools.zip merge --aov-output ALBEDO albedo.png film.flm
[MainThread][2020-05-07 12:15:11,142] LuxCore 2.4alpha0
[MainThread][2020-05-07 12:15:11,143] Processing the base Film: film.flm
[MainThread][2020-05-07 12:15:11,341] Resulting film statistics:
[MainThread][2020-05-07 12:15:11,341] Samples per pixel: 42.588431249999999
[MainThread][2020-05-07 12:15:11,341] Radiance group count: 1
[MainThread][2020-05-07 12:15:11,341] [LuxCore][0.200] Outputting film: albedo.png type: 31
[MainThread][2020-05-07 12:15:11,366] Done.
Wow!!!!!
Thank you. I’ll give you soon a feedback!
I have just tried to export ALBEDO in two ways like in the example you posted here but no output for me. Am I wrong? Can you help me?
1)
python3 /Applications/LuxCoreRender/pyluxcore/pyluxcoretools.zip merge -a ALBEDO ParzialeAlbedo.png -f /Users/vza/Desktop/Render3/Fiordo7_Dettaglio_LuxCore/00001/film.flm
[MainThread][2020-05-07 21:18:30,347] LuxCore 2.4alpha0
usage: pyluxcoretools.zip [-o FILE_NAME] [-f FILE_NAME] [-h]
[-a AOV_NAME FILE_NAME]
PyLuxCoreMerge
optional arguments:
-o FILE_NAME, --image-output FILE_NAME
Save the RGB_IMAGEPIPELINE film output to a file
-f FILE_NAME, --film-output FILE_NAME
Save the merge film to a file
-h, --help Show this help message and exit
-a AOV_NAME FILE_NAME, --aov-output AOV_NAME FILE_NAME
Save the merge film AOV to a file
usage: pyluxcoretools.zip [-p] [-s]
[-r SRC_OFFSET_X SRC_OFFSET_Y SRC_WIDTH SRC_HEIGHT DST_OFFSET_X DST_OFFSET_Y]
fileFilm
Film Options
positional arguments:
fileFilm .cfg, .flm or .rsm files with a film
optional arguments:
-p, --pixel-normalized-channel
The film will have
CHANNEL_RADIANCE_PER_PIXEL_NORMALIZED (required by all
render engines)
-s, --screen-normalized-channel
The film will have
CHANNEL_RADIANCE_PER_SCREEN_NORMALIZED (required by
BIDIRCPU and LIGHTCPU render engines)
-r SRC_OFFSET_X SRC_OFFSET_Y SRC_WIDTH SRC_HEIGHT DST_OFFSET_X DST_OFFSET_Y, --region SRC_OFFSET_X SRC_OFFSET_Y SRC_WIDTH SRC_HEIGHT DST_OFFSET_X DST_OFFSET_Y
Define the origin and the size of the region in the
source film and the placement in the destination film
where the it will be merged
2)
python3 /Applications/LuxCoreRender/pyluxcore/pyluxcoretools.zip merge --aov-output ALBEDO ParzialeAlbedo.png /Users/vza/Desktop/Render3/Fiordo7_Dettaglio_LuxCore/00001/film.flm
[MainThread][2020-05-07 21:20:28,976] LuxCore 2.4alpha0
[MainThread][2020-05-07 21:20:28,978] Processing the base Film: /Users/vza/Desktop/Render3/Fiordo7_Dettaglio_LuxCore/00001/film.flm
[MainThread][2020-05-07 21:20:29,889] Resulting film statistics:
[MainThread][2020-05-07 21:20:29,889] Samples per pixel: 41.952010030864194
[MainThread][2020-05-07 21:20:29,889] Radiance group count: 4
************* no output here************************
[MainThread][2020-05-07 21:20:29,889] Done.
1)
PyLuxCoreMerge
optional arguments:
fileFilm
Film Options
optional arguments:
The film will have
render engines)
The film will have
2)
The second looks correct to me but I have the feeling your .flm doesn't have an ALBEDO AOV inside. Tomorrow I will add some check so you get an warning message in that case. Can you do a test with a small .flm and post the file ?
I think the problem is in 2.40 standalone because I can open the app but it can't load .cfg file and then I have to kill the process and restart my mac because some other application (Blender, Safari) don't run anymore.
This is likely to be the MacOS OpenCL broken drivers taking 1 hour to compile the kernel. It shouldn't happen if you render with the CPU.vza wrote: Fri May 08, 2020 9:40 am I think the problem is in 2.40 standalone because I can open the app but it can't load .cfg file and then I have to kill the process and restart my mac because some other application (Blender, Safari) don't run anymore.
You are right!
With CPU it works fine, so my solution is to use BlendLuxCore v2.3 with GPU for normal scenes and v.2.4 (CPU) for super-complex scenes in network render and extract passes from merged .flm.
However I think I won't be able to use BlendLuxCore with openCL from version 2.4 and later.
Thank you very much!
