Hello!
I'm using the network tool and the PyLuxCoreMerge to export the result in .exr format. Is there a way to export it as a multilayers image? If not, can you export the single image pipelines as "direct glossy" or "shadows"? In .png format can you specify if 16 or 8 bit? Thanks a lot!
From .flm to .exr or .png16bit
Re: From .flm to .exr or .png16bit
Nope.
Yes, you can use the "OUTPUT_SWITCHER" image pipeline plugin to replace the rendering with any AOV: https://github.com/LuxCoreRender/LuxCor ... itcher.cpp
But are you using BlendLuxCore or working directly with LuxCoreRender standalone ?
Nope, it is always 8bit.
Thank you very, very much for your answer Dade!
"But are you using BlendLuxCore or working directly with LuxCoreRender standalone ?"
->I'm using BlendLuxCore, but I tried to launch the same rendering with LuxCoreRender standalone because BlendLuxCore, in network render, ignores the output file format (.exr) and saves the result directly in .png 8bit.
From terminal (OSX) I launched "python3 "pyluxcoretool.zip" and then merged .flm files, saving with .exr extension. I would like to do the same process with all passes I need.
This may be a bit complex because you have to save the scene in text format and than edit the .cfg file by hand and define a custom image pipeline and outputs with what you need.
Ok! No problem in editing .cfg file, but the "problem" is only in network process because you can add only jobs in binary format! So my idea was to export passes from the final .flm without launching one render for every pass I need. Is it possible? Naturally only for super complex scene, in normal scenes i will use BlenderLuxCore!This may be a bit complex because you have to save the scene in text format and than edit the .cfg file by hand and define a custom image pipeline and outputs with what you need.
It is possible to load a text scene in LuxCoreUI (standalone executable) and from there export in binary format but, ok, it is super tricky.vza wrote: ↑Wed May 06, 2020 7:48 amOk! No problem in editing .cfg file, but the "problem" is only in network process because you can add only jobs in binary format!This may be a bit complex because you have to save the scene in text format and than edit the .cfg file by hand and define a custom image pipeline and outputs with what you need.
It is an option pretty easy to add to "pyluxcoretools merge" (you can already merge with just one film). Are you using the under development v2.4 ?
No, I'm using LuxCore v2.3!
I can modify merge tool to add the option to save a specific AOV however you will have to use the v2.4
Great!!! Very useful!! I'm using v. 2.3 for Mac because I found this version in the download section of this site, but I will use 2.4! No problem! I'm working with LuxCore for 15 days and I'm literally in love with it! Thanks to you and to all other developers! Can you link here a webpage where I can find instructions to install v2.4 on OSX?
