Did you do any profiling yet to find the hotspots in the interpreter?
v2.3 Vs v2.4 performance
Re: v2.3 Vs v2.4 performance
Comparison with v2.2 is even scarier:
this is a lot even between 2.2 and 2.3 there is half performance lost.epilectrolytics wrote: ↑Fri May 01, 2020 9:06 am Comparison with v2.2 is even scarier:
Here are results with GTX970 (2.3 vs. 2.4 build 20200430.12):
On this card CUDA underperforms OpenCL quite a bit...
Anyone else with this or similar GPU series can confirm?
P.S. With the very latest build, LuxCoreUI exits without any error message while evaluating PhotonGI best radius:
[LuxRays][1.828] [MBVHKernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D PARAM_RAY_EPSILON_MIN=0.0001f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_OPENCL_DEVICE -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][1.828] [MBVHKernel] Compiling kernels
[LuxRays][1.828] [MBVHKernel] Program cached
[LuxCore][1.859] [PathOCLRenderEngine] OpenCL task count: 262144
[LuxCore][1.859] [PathOCLBaseRenderEngine] OpenCL max. page memory size: 1048576Kbytes
[LuxCore][1.859] PhotonGI evaluating best radius
C:\Users\Alessandro\Desktop\luxcorerender-latest-win64-cuda\scenes\LuxCore2.1Benchmark\LuxCoreScene>
A 970 GTX can not be 7 times slower than a 2070 RTX
Indeed! I dont' understand if it can be something broken on my system or not...
I tested both with Azure-built and self-built binaries, results are the same.
