Windows Build FAILED
acasta69
Re: Windows Build FAILED
Post by acasta69 »
Dade wrote: Mon Apr 27, 2020 1:54 pm This is probably because we are the one to load the main nvrtc64_101_0.dll while it is the nvrtc64_101_0.dll to load nvrtc-builtins64_101.dll. Different settings may apply to the two different DLL loads. The first load probably uses the Python settings while the second may only use the System one :?:
B.Y.O.B. wrote: Mon Apr 27, 2020 1:57 pm I have pushed a fix: https://github.com/LuxCoreRender/BlendL ... edae1a088f
Does it work on your end?
So, after removing DLL location from system PATH, I had the same problem on the laptop, while everything was ok on the desktop.
With B.Y.O.B.'s fix, it's working on both.
I am also wondering why there is no problem with LuxcoreUI. Maybe some difference because of the Python environment :?:
B.Y.O.B. wrote: Mon Apr 27, 2020 5:38 pm I'm also getting crashes with regular OpenCL with the latest builds, for example in the danish mood scene. In simple cube-type scenes it works.
To be more precise, here is a log:
[LuxCore][14.922] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][14.922] [PathOCLBaseRenderThread::0] AdvancePaths_MK_* workgroup size: 32
[LuxCore][14.922] [PathOCLBaseRenderThread::0] Kernels compilation time: 62ms
[LuxCore][14.938] Starting 0 native render threads
Session started in 1.2 s
[LuxCore][14.953] Film hardware image pipeline
[LuxCore][14.953] Film hardware device used: GeForce RTX 2080 OpenCLIntersect (Type: OPENCL_GPU)
[LuxCore][14.953]   Device OpenCL version: OpenCL 1.2 CUDA
Error   : Unrecognized Exception
Address : 0x00007FFDE740A799
Module  : C:\WINDOWS\System32\KERNELBASE.dll
The OpenCL devices are working fine here with all test scenes, in or outside Blender :?:
Are you using the OpenCL or the CUDA binaries ? Just load DanishMood scene, press F12 and get a crash ?
Dade wrote: Tue Apr 28, 2020 10:24 am The OpenCL devices are working fine here with all test scenes, in or outside Blender :?:
It happens only on Windows...
Dade wrote: Tue Apr 28, 2020 10:46 am
However, only Blender crashes, LuxCoreUI is working fine :?:
B.Y.O.B., can you check if the BlendLuxCore DLL fix hasn't, for some strange reason, broken OpenCL driver ?
johannes.wilde
Post by johannes.wilde »
For me the BlendLuxCore Build from yesterday evening works.
But every time i hit render, it compiles the kernels again, so it's quite a time to wait.
Dade wrote: Tue Apr 28, 2020 10:53 am B.Y.O.B., can you check if the BlendLuxCore DLL fix hasn't, for some strange reason, broken OpenCL driver ?
It was crashing even before I applied the DLL fix.
B.Y.O.B. wrote: Tue Apr 28, 2020 11:04 am
I should (may ?) have fixed the problem.
neo2068
Post by neo2068 »
neo2068 wrote: Mon Apr 27, 2020 6:21 pm I get errors with latest build and OpenCL and the food demo scene, too, e.g. PATHOCL:clFinish(CL_INVALID_COMMAND_QUEUE) or TILEPATHOCL: clEnqueueReadBuffer(CL_OUT_OF_RESOURCES). With cuda my GTX 780 is 1.5 times faster than the GTX 1080. Is it normal behaviour?
Dade wrote: Tue Apr 28, 2020 10:53 am However, only Blender crashes, LuxCoreUI is working fine :?:
For me, the error messages happen with LuxCoreUI under windows with opencl devices and the cuda build.
neo2068 wrote: Tue Apr 28, 2020 2:21 pm
Have you tried the latest sources ?
